procharger (red) valve
Old May 16, 2011 | 10:57 AM
chevytk's Avatar
Default procharger (red) valve
I've seen some videos of this red race procharger valve and it sounds sick... What is the difference to install this one instead of the stock small black one... What modifications need to be done? What are the advantages or disadvantages? It will be for a 2002 5.3 silverado daily driver...
Old May 16, 2011 | 11:13 AM
Mangled03gmc's Avatar
Baltimore Whore
It just vents more air out.. It is set up like a blow off valve is for a turbo, or should I say the housing is. It is diff then the pro flo valve.. If you want some sound to it, do not want to spend a ton on the red valve, get a vortec valve for it.. This was on my P1 on 6psi. It is a bit louder now on the D1, more boost..
http://www.youtube.com/watch?v=HwOV06jJqNc
Old May 16, 2011 | 05:00 PM
ls36.2's Avatar
did you make that t piping or did you get the piping with the blow off valve
Old May 16, 2011 | 05:03 PM
Baltimore Whore
I bought that with the bolt on flange..
Old May 16, 2011 | 06:15 PM
slowlsx's Avatar
whats the price on the big red procharger valve?
Old May 17, 2011 | 11:25 AM
chevytk's Avatar
damn... that sounds very nice... and how much does that vortech one run for? And its an open valve correct?
Old May 17, 2011 | 11:44 AM
sharpshooter's Avatar
the red one doesn't sound like that-ask Sureshot
Old May 17, 2011 | 04:03 PM
idahoblkss's Avatar
this is how my valve cam...
it also came with a lil piece of pipe that you will need to weld to a 3" piece of pipe to make the "T" so you can mount it in your system any welder should be able to do this no problem. the red lave is like 400 brand new but if you watch ebay you'll see them for around 300 evey now and then. the red valve is defiantly the loudest valve i have heard hands down.
you can kinda see how its mounted in this pic....
lil video in action ...
and you will probably see a gain in boost from going to the red valve over the stock one, well i did anyway, i dont think the stock one seals all the way.
chopperloco
Sep 28, 2015 08:40 AM
MOBBN
Sep 22, 2015 08:07 PM
fortune46x
Sep 16, 2015 08:18 AM
00loudchevy
Sep 11, 2015 07:55 AM
Justin87gn
Sep 10, 2015 12:06 PM
