Procharger Guys come in!!
I have a few questions for you guys so that i can finish my install...
- What size belt is needed for a D1sc kit with a 4" pulley?
-Where do i plug the vac. line from the Bypass valve in to? I have the Big Red Valve.
Thanks
Thanks
You can plug the line into the hose coming from the back of the intake mani(the one that runs to the brake booster-master cyl.. You need to get a vacuum T to make it all work. As far as belt goes I am not sure. I am running a gates- k061110.. I am running a 3.50 pulley, so you might need to go to a bigger size, as my tensioner is pulled just about all the way in..
You should try for a direct line to the intake ,no "T"s , good solid connections that won't seperate. I run DOT airline with pushlok fittings.
My notes show a Gates K061115 w/ a 4" pulley and a K061105 for a 3.5" pulley
I agree that if you can get it to the intake that would prob be best.. But as long as it is a good quality T it will work just as good, so long you have the tubes secured correct...
