Pics of turbo oil return to timing cover
Old May 10, 2020 | 08:32 PM
pknowles's Avatar
Default Pics of turbo oil return to timing cover
I ordered a kit from Trick Turbo for my 2001 Siliverado with an LQ4 and I'm trying to figure out how I want to run the oil return. Any one run it to the timing cover? any pics? parts? I plan to use the stock balancer, Any help would be great. Thanks.
Old May 10, 2020 | 09:54 PM
arthursc2's Avatar
Making this post to remind myself to post pics
Old May 13, 2020 | 10:48 AM
arthursc2's Avatar
Pics of the drains I installed when I either built a motor or swapped covers. Futureproofing my builds. Both covers are 1/2NPT and currently plugged. Drilled as low and as right as possible in the cover
1st pics with Corvette spacing, 2nd pics with truck spacing
Old May 14, 2020 | 05:29 AM
infam0us1's Avatar
What would be the benefit of the cover v/s the pan?
Old May 14, 2020 | 07:41 AM
arthursc2's Avatar
Easier to get to and modify, no chips in the engine when you mod it, always above the oil fill, easier to route your line to it. Etc
Old Jul 13, 2020 | 01:57 PM
usafws6's Avatar
Tuner Lvl 0
it's a huge pain IMHO. I have two drains into the timing cover. But it does work.
Old Jul 14, 2020 | 06:51 AM
6.0 pickup's Avatar
5 Year Member
QQ
Just understand that fitting is exactly over oil pump mounting bolt. If fitting stick out from inside cover it will be over bolt head which WILL stop oil from enter pan... just keep fitting flush On inside of cover. I had to cut off 3/8” from fitting plus I grinded insid eof fitting like funnel for better oil flow ... that 10an 1/2 npt 45*
Old Jul 14, 2020 | 12:26 PM
Atomic's Avatar
I have a gauge for that
I went to the front of the pan with it off the truck just below the timing cover. I also have an OD crank pulley so no way was a fitting going to fit on the timing cover.
Old Jul 16, 2020 | 04:11 PM
hoo-dat's Avatar
Rick can build you a cover with the drain too if needed
ChevyThunder17
Feb 17, 2020 12:39 PM
chvy=power
Jul 12, 2016 09:17 AM
evand
Feb 15, 2012 10:12 AM
02'Z71ONDUBZ'
May 6, 2010 01:26 AM
Rns10s
Jan 31, 2006 12:17 PM
