05 Silverado Procharger?
Old Jul 16, 2020 | 06:37 PM
Jarod910's Avatar
Registered User
Default 05 Silverado Procharger?
I’ve got an 05 2500hd with the LQ4 6.0 engine. For the last year or so I’ve been looking at boosting it and trying to get some power under the hood. I was entertaining the idea of the turbo but I feel that’s too common and I want something different. I’m wanting to put a Procharger on it and want some opinions on where to get a good one. I see jegs has them and summit does as well but one big question of mine is what is needed. Obviously the Procharger itself and an inter cooler. I can do all the fab work for pipes myself. Other than those three things what is needed. As turbos need oil lines and such. What all is needed and where is a good place to get one.
Old Jul 16, 2020 | 06:57 PM
FFDP's Avatar
Most procharger kits are bolt on units as far as that goes. It's going to have all the pieces for that kit.
What it may not come with is a fuel system. So you'd need larger injectors and fuel pump. Probably a 2 or 3 bar MAP sensor too if that is not included.
Old Jul 16, 2020 | 07:10 PM
tjmath's Avatar
And tuning. I would opt for the kit that does not come with the preloaded handheald tuner have it professionally tuned
Old Jul 16, 2020 | 07:20 PM
Jarod910's Avatar
Registered User
okay I have been watching rayspec on YouTube and his had a mounting bracket that mounted right up by the alternator. All I have been around is ls motors so is that a universal mount spot for that? I planned on going with 75lb per hour injectors if not bigger
Old Jul 17, 2020 | 08:40 PM
darkirish63's Avatar
Check out the dedicated drive kits on House of Boost.
00loudchevy
May 20, 2014 08:32 AM
hemidup
Sep 29, 2008 09:09 AM
Mangled03gmc
29
Jun 19, 2008 11:34 PM
ND RAM
Jan 25, 2007 12:32 AM
work in progress
Sep 20, 2002 09:29 PM
