Passing inspection in NC with turbo kit.
Old Nov 10, 2019 | 09:38 AM
TAPyvehc93's Avatar
Default Passing inspection in NC with turbo kit.
I’m coming up on my first state inspection in NC with my truck and I’m not sure what to expect. I don’t believe they do a sniffer test here. I think it’s just a visual inspection and a OBDII reading. The only issue is that I don’t have a catalytic converter. Would it be as simple as installing a dummy cat and sending it on it’s way? What have you done. Thanks.
Old Nov 10, 2019 | 08:50 PM
Jonblarc7's Avatar
As long as the truck doesn’t throw a check engine light your fine. My Y pipe with my headers on my old truck didn’t have any cats. I never had a problem because they don’t even put it on a lift to look.
The only problem I ever ran into is one time a tech wanted to be a punk and failed me because I had my rear resonator cut off and left dumped over the rear axle. He said I needed a pipe that exited the under side of the vehicle. Every other nobody ever said anything
Old Nov 11, 2019 | 06:22 AM
TAPyvehc93's Avatar
Yeah, I have mine dumped before the rear axle 😬😬.
Old Nov 11, 2019 | 07:42 AM
Jonblarc7's Avatar
You might be alright, I passed several years without anybody saying anything but there's always that one guy.
I still had the piece I cut off so I just used a band clamp and clamped it on then went right back and got it passed.
I guessing you probably can't do that.
Old Nov 11, 2019 | 12:46 PM
TAPyvehc93's Avatar
Yeah, I ended up just buying a 4” cat. I’ll just gut it, weld it up in there and be done with it. Iv been wanting to install a “resonator” anyways lol
Old Nov 11, 2019 | 04:46 PM
esoteric_ast's Avatar
What county are you in? Some no longer require emissions testing.
Old Nov 12, 2019 | 05:28 AM
Jonblarc7's Avatar
It’s called the South!!!! It’s pretty awesome LOL
Old Nov 13, 2019 | 11:26 AM
Alvin@PCMofNC's Avatar
Truck Sponsor
If you're in Mooresville/Iredell/Rowan Co then there is no sniffer. Just OBDII plug in & visual inspection.
HuskerZ71
Jan 17, 2013 01:38 AM
Static54
Aug 19, 2011 02:59 PM
NoShow
Jan 24, 2010 08:30 AM
Cakes
Aug 27, 2009 07:22 PM
hmatiak
14
Jan 4, 2008 08:38 AM
