Oil supply for turbos
Old Dec 5, 2010 | 03:40 PM
Hemitruck04's Avatar
Default Oil supply for turbos
I was wondering if I could use the 2 test ports near the oil filter on the engine to supply my turbos with oil? Engine is a 5.7 engine
Old Dec 5, 2010 | 04:06 PM
tarinitup's Avatar
9 Second Truck Club
That is where most people tap into for oil supply on Gm trucks.
Old Dec 5, 2010 | 04:42 PM
Awsome to know I have 2 ports there as a matter of fact.
Old Dec 6, 2010 | 08:40 AM
Gadgetized's Avatar
Make sure you use oil restrictors.
Old Dec 6, 2010 | 12:06 PM
SRTKLLR's Avatar
When the shop installed the turbo on the Hemi they used a "T" where the oil pressure sensor is at the front of the motor to supply oil to the turbo.
Old Dec 6, 2010 | 02:38 PM
Bluchevypick's Avatar
Im not using a restrictor on mine and run a -4 line with no problems
Old Dec 7, 2010 | 08:28 AM
Right the oil pressure sensor is right there up front, if you look back on the left there are 2 test ports rather than using a T correct?
Old Dec 7, 2010 | 09:33 AM
blue0453's Avatar
Same here, no problems.
zblee
63
Jun 10, 2023 01:25 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ls3silverado
Jul 31, 2015 04:22 PM
Gadgetized
Jul 22, 2015 11:55 AM
Mzay
Jul 6, 2015 11:03 PM
