Oil feed and return lines??
Old Mar 7, 2012 | 04:35 PM
black04silverado's Avatar
Default Oil feed and return lines??
I Got my kb turbo kit and im getting ready to install it.
what im needing to know is my truck has the factory oil cooler so where can i tap into to get oil? I have seen the trick plate but im looking for something I can do without having to order any more parts.
also where do i tap the pan at for the return line?
pics would be great thanks guys.
Old Mar 7, 2012 | 05:13 PM
black6spdz's Avatar
I tapped mine right into the stock aluminum block that the cooler lines come out of. I took it off drilled and tapped it 1/8" pipe and put my fitting in. this way i could keep the stock oil cooler. For the return i drilled and tapped the front of the pan right below the crank and put my fitting in, no leaks yet.
Old Mar 7, 2012 | 05:30 PM
robbyredneck's Avatar
carefull with the cooler block though there is a bypass spring in there. my return is in the front also but i am the jackass that put it right under a pan bolt.
Old Mar 7, 2012 | 05:36 PM
Do you have any pictures of your return line?
Old Mar 7, 2012 | 05:42 PM
nope, but i drilled mine when i did the engine swap. right below the a/c belt. most guys say you can easily reach here with the pan on.
kbracing96's Avatar
Here is mine...
Old Mar 7, 2012 | 09:27 PM
Originally Posted by kbracing96
Here is mine...
Thanks kyle!
I guess I will be doing that tomorrow.
Old Mar 8, 2012 | 06:54 AM
nodrok's Avatar
Here is mine...
Thats where mine is under the started. I tapped the oil cooler block. But trick performance offers a nice bolt on piece that goes im between the engine block and cooler lines. I would just buy it.
Old Mar 8, 2012 | 10:55 AM
Alpinestar's Avatar
When am I going to have to start worrying about another turbo'd truck in Norman?
I'm not sure how the oil cooler guys do their feed lines but trick's piece looks simple and I wouldn't worry about it leaking oil. Here is where I ran my drain line.
Old Mar 8, 2012 | 11:03 AM
Atomic's Avatar
I have a gauge for that
Heres mine for my custom oil cooler and temp sensor
