Oil feed and return lines??
Old Mar 8, 2012 | 11:12 AM
black04silverado's Avatar
Originally Posted by Alpinestar
When am I going to have to start worrying about another turbo'd truck in Norman?
I'm not sure how the oil cooler guys do their feed lines but trick's piece looks simple and I wouldn't worry about it leaking oil. Here is where I ran my drain line.
I plan on installing the kit tonight. maybe have it all running by the end of the week.
Also my buddy bought his kit last night hes doing a lq4 swap with the turbo.
I would like to take a look at your truck sometime if you dont mind, just to get an idea of where everything is going to go.
Thanks for the pics guys!
Old Aug 12, 2013 | 12:04 PM
darnie's Avatar
this is how i plan on running mine, how hard was it to drop the pan? i know theres alot of small bolts on the pan but is there anything i need to remove since im 4x4?
Old Aug 12, 2013 | 12:32 PM
ChEvY mAn 707's Avatar
Good luck on a 4wd, you can either unbolt the motor mounts and raise the motor and get the pan that way or, like my 4wd the steering stabilizer and front diff were in the way to get some bolts. So I just kept the pan on, drilled and tapped it, lots of grease and take your time.
Old Aug 12, 2013 | 12:36 PM
Choda's Avatar
I left my 4x4 pan on and tapped the front like that pic. Works great.
Old Aug 12, 2013 | 10:00 PM
Hivelocit's Avatar
Careful of getting shavings inside pan though! Might be worth the extra hassle to take it off.
Old Aug 13, 2013 | 07:58 AM
darnie's Avatar
ya being that its 4x4 thats where im having the issues figuring out exactily what/how to do it., alot of the write ups are for the 2wd.
Old Aug 13, 2013 | 08:03 AM
smokeshow's Avatar
Mod with training wheels
You can unbolt the front diff to drop it down a few inches and get the pan out.
Old Aug 13, 2013 | 08:54 AM
Bama2door's Avatar
For my feed I got the Trick plate, little expensive but it was worth it. As for the drain, i took the timing cover off and drilled and taped the bottom left side.
Old Aug 14, 2013 | 12:42 AM
darnie's Avatar
what would be easyer to remove on the 4x4 timing cover or the oil pan?
Old Mar 15, 2014 | 05:05 PM
cpolaris502's Avatar
Bringing this thread back up from my search.
Does anyone T their feed line off at the oil sender behind the intake? I have seen a few people do it that way, one SBC and a 5.3l. Is there anything wrong with doing that?
