My cheapish catch can
Old Oct 23, 2008 | 03:55 PM
KySilverado's Avatar
Default My cheapish catch can
Last time I pulled off my J-tube I noticed a little oil. I've never added any oil to the truck between changes. Wasn't really worried about it.
Finally got around to putting a little catch can on it. Got it from Jegs'. Can't say that I would recommend it. After getting it on I heard a little hiss. Put my hand around the bowl and it stops. Anyway put some sealer on the bowl threads and wrapped it up with electrical tape to get it to stop.
Got home today from work. One trip to and from work with a good pull through second gear at lunch got me this.
One thing I noticed while installing it. The PCV valve in the valve cover doesn't have anything in it. Not poppet, no spring, nada.... Is that the way they are?
Old Oct 23, 2008 | 04:05 PM
silver-mod-o's Avatar
Hunt&Fisherator
I just changed my PCV today too... Mines got a check valve in it. I need a catch can myself... I put a breather on the pass side valve cover but its still pushing a little oil under boost. I've got my eye on one from Summit... its similar to that one, just a size bigger I believe...
Old Oct 23, 2008 | 04:17 PM
TXsilverado's Avatar
there are 2 different style pcv valves...the old style with the spring and valve, and the updated pcv valve with nothing but a little hole. both suck IMO
Old Oct 23, 2008 | 04:19 PM
BlackGMC's Avatar
Resident Retard
I got one of these...
The insides of it
Old Oct 23, 2008 | 04:24 PM
Yes they do suck.... literally. A lot!
I've looked a various PCV systems... and am a bit embarrassed that I don't understand such a simple system. Do I need to put another can for the line into the passenger valve cover?
Old Oct 23, 2008 | 04:26 PM
The insides of it
Yeah after seeing what I really am getting caught maybe I need to do a better one. I looked at these also but more than I wanted to spend for it. Maybe I should have spent the coin.
Old Oct 23, 2008 | 04:27 PM
BlackGMC's Avatar
Resident Retard
Isn't the passenger side a vent? Means it actually sucks air in... I am not sure how it is configured on a supercharger setup....
Old Oct 23, 2008 | 04:28 PM
BlackGMC's Avatar
Resident Retard
It was an impluse buy, kinda regretted afterwards, but oh well.... Still have nto installed, maybe next week...
Old Oct 23, 2008 | 04:31 PM
Its run into the intake tube before the TB. So yeah should be pulling air from the intake tube at low loads and high manifold vacuum. But under load and no manifold vacuum I think it would then flow from the engine into the intake? Thats part of what I don't understand.
Old Oct 23, 2008 | 04:38 PM
Bet you don't have to wrap electrical tape around it to get it to seal
