mp122 belt tensioner alignment question
Old Aug 15, 2013 | 08:59 PM
trxmxzx's Avatar
13 Second Truck Club
Default mp122 belt tensioner alignment question
Well installed the blower few months ago, and i managed to shredded a belt -found that one of my pulley is not offset enough so the belt was hanging off a little. well i went to auto store got another pulley with 3mm more offset which its closer but the belt still hangs off like a 1/8- 1/16 . i used stock idler like the instructions said. any ideas or part numbers i can use to fix this problem? i dont want to do the same thing to the new belt. heres some pics. the pulley i have issues with is the one with the green seal.
before i changed idler
the idler that caused the damage- bad pic
new one
the offset and over hang
Old Aug 15, 2013 | 09:19 PM
Gadgetized's Avatar
When you have a shiny spot in front of the belt around the water pump, it usually means the pulley is walkong off.
Old Aug 15, 2013 | 09:27 PM
trxmxzx's Avatar
are you talking like the crank pulley spinning on crank? which pulley is my concern. im sorry im not understanding fully.
Old Aug 15, 2013 | 10:44 PM
Gadgetized's Avatar
Sorry I was looking on my phone, and it looked like the water pump pulley. Afrer looking closer it appears to be the passenger idler. If there is the worn area in front of the belt it is telling you that at one time it was riding at the edge of that worn area. Now that the worn area is ahead of the belt it is telling you that something is moving. I would remove the belt and check all the pullies and idlers for any play. If there is play the bearings or the idlers need to be replaced. The cheapest easiest way I feel to check for alignment is with a straight edge. Place the belt on and run a straight edge across the pulley, and parallel with the belt. If it is off, it should show up pretty easily.
Old Aug 15, 2013 | 11:57 PM
Blown06's Avatar
8 Second Truck Club
You need to move the pulley toward the motor correct? If so, the only way to fix that is a new bracket with proper standoff or you can send me the bracket you have and I will mill it down for ya.
Old Aug 16, 2013 | 07:48 PM
trxmxzx's Avatar
Thanks for the replies!! Yes the pulley needs to move back towards the motor. I was also wondering about having to mill the bracket. I was just hoping for a pulley swap! Is this a common issue? Blown06 thanks for the offer I'm going to check with a neighbor that has a Bridgeport first.
Old Aug 16, 2013 | 11:15 PM
Blown06's Avatar
8 Second Truck Club
Good idea with the neighbor. Should be a free fix that way. Weird things can happen with pulley alignment. Check out the Gates laser alignment tool. It may freak you out if you use that on all your pulleys. I've had to put washers behind stuff to space it right on supercharged stuff. The laser doesn't lie. When running a blower and high rpm off the serp. belt it makes all the difference in the world. It will keep you from wanting to put a ricer turbo on your stuff.
Old Aug 17, 2013 | 05:47 PM
trxmxzx's Avatar
So took the truck out today, the pulley looked worse than before I loosened set bolt the pulley had some play in it. Reset it and now it's straight. So took it out for the Woodward dream cruise put about 60 miles on it and rechecked it everything is still straight. Just have to see how long this lasts.
Thanks for the help again guys
Old Aug 18, 2013 | 12:06 AM
therock's Avatar
My old post here may help you. I had to machine off a few mm of a bushing/spacer.
Older post so the prices are different. O'Riley's carries most of it. Until I changed into that Gates tensioner I got a little rubber dust on the blower snout. I only runs Gates belts.
Here
blownss27
Aug 14, 2020 08:27 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
hackrst
Sep 2, 2015 05:27 PM
fctry286
Aug 20, 2015 09:21 PM
