meth injection guys CHIME IN!!
Old Oct 31, 2006 | 06:22 PM
whoopassracer's Avatar
Default meth injection guys CHIME IN!!
do any of you guys have pics of the meth kit installation. if so can you please post it up so that i can get somewhat of an idea how to install it correctly
Old Oct 31, 2006 | 07:57 PM
Wilde Racing's Avatar
How do I change this text
Well I don't have a air box so I mounted mine there. If you would like better pic, just let me know....
Old Oct 31, 2006 | 08:19 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
If you look under my hood you probably won't notice the meth kit. If you look hard you will see a single braided hose running to the intake tube.
Notice the braided hose running around and behind?
Under the front driver side wheel well you might notice the pump. All the electronics are up under the dash, hidden from prying eyes.
Old Oct 31, 2006 | 10:42 PM
DrX's Avatar
DrX
Lots of different ways to install the kits. Just follow the instructions carefully with respect to mounting heights, check valves, nozzle sizes, etc. I would like to get a larger reservoir for mine if I can find a good mounting location. 2L doesn't go very far if you have a heavy foot. I would also use braided lines if you intend to use over a 50% meth mixture.
My pump is angled to clear the hood hinge spring.
Controller.
LED
Old Nov 1, 2006 | 07:04 AM
JERRY2500's Avatar
14 Second Truck Club
Here's some pic of mine >>>>> https://www.performancetrucks.net/fo...d.php?t=322500
Old Nov 1, 2006 | 02:08 PM
KY_BOB's Avatar
Mine was built by SMC. Come to find out a washer fluid tank from a Mitsu Evo fits the fan shroud perfect.
Attached Thumbnails meth injection guys CHIME IN!!-meth.jpg   meth injection guys CHIME IN!!-meth4.jpg   meth injection guys CHIME IN!!-meth6.jpg   meth injection guys CHIME IN!!-meth8.jpg
Old Nov 1, 2006 | 05:41 PM
and is it best to put the pump as close and a little below the tank
Old Nov 1, 2006 | 06:39 PM
cmiller's Avatar
just wondering what is meth i have no idea
Old Nov 1, 2006 | 06:50 PM
trever1t's Avatar
cmiller, Meth (methanol) is commonly called wood alcohol and is used to lower intake manifold temperature and increase octane. This allows the potentail for more timing without detonation (knock) in a forced induction aplication.
Correct me if i missed something.
Old Nov 1, 2006 | 07:00 PM
Sounds correct to me!
Alkycontrol will be my meth kit! Finally made my decision!
Jim
