meth injection guys CHIME IN!!
Old Nov 1, 2006 | 08:18 PM
  #21
whoopassracer's Avatar
so what size is your new tank trever1t
Old Nov 1, 2006 | 08:21 PM
  #22
man by going with meth and then SD Tune wow im hoping to see a very powerfull increase. so what r your predictions on my tims, before my times were a 13.67@94mph with iats around 210 with a 1.79 60foot.
Old Nov 1, 2006 | 08:22 PM
  #23
Last Call's Avatar
TOTM: January 2007
Originally Posted by CHEVY6000VHO
Where does the washer fluid tank mount at for the Alky kit??
Your not using the actual washer fluid tank that is mounted in the inner left front fender are you?
I'm confused abou this part..........
Jim
Yes, the Alkycontrol kit comes with a new GM washer reservoir fitted with a methanol fitting at the bottom. It also comes with a smaller reservoir for the windshield washer. The advanatge is larger capacity and lower washer fluid warning light so you dont get into boost when there is no methanol. I like my kit so far. It makes the truck run consistent regardless of outside temps.
Originally Posted by whoopassracer
by doing that when turning the wheel it wont hit the pump or what i was thinking of doing that also
The wheel will not hit the pump. I have 305/35R22's on a 3/4 drop and there is plenty of clearance there. I would get some pics, but it is cold and dark outside. lol Tomorrow I can.
Old Nov 1, 2006 | 08:24 PM
  #24
Last Call's Avatar
TOTM: January 2007
This is Trever1T's set up. Inside drivers front fenderwell.
Old Nov 1, 2006 | 08:27 PM
  #25
so then you all are using the same washerfluid tank but new which is a 1 gallon tank right j
Old Nov 1, 2006 | 08:44 PM
  #26
Last Call's Avatar
TOTM: January 2007
Yes, not sure the exact size, but at least 1 gallon. I go through it fast too.
As far as your times... I just dont get them. lol You had awesome times in Washington, 12.79 with minimal mods. Then the times in Texas are more to par with what I have ran at the track w/ similar mods. Not sure bro.
Old Nov 1, 2006 | 09:54 PM
  #27
10/4 chet the way things are going so see how the sd tune comes out
Old Nov 1, 2006 | 10:01 PM
  #28
bud8fan's Avatar
on the inline checkvalve do the arrows face towards the intake or pump
they face toward the intake...it's the direction of the flow of your fluid from the pump....
Old Nov 1, 2006 | 10:03 PM
  #29
hey supp man
havent heard from ya a ,,,10/4
hey quick question where did u mount your pump
and where did u make the hole on the washerfluid tank for the fitting
im going to allen's shop next thursday for the sd tune dyno
Old Nov 2, 2006 | 07:32 PM
  #30
well im going to use my windshield washerfluid tank and put the pump on the passenger side firewall
