meth injection guys CHIME IN!!
Old Nov 1, 2006 | 07:11 PM
cmiller's Avatar
were do you by the methanol
Old Nov 1, 2006 | 07:13 PM
whoopassracer's Avatar
hey Drx what size is your tank is it a 1 gallon or 2quarts original tank for snowperformacne
trever1t's Avatar
2nd fastest 5.3 ECSB
Take some corn and some water ................
Just kidding. Race fuel supply stores or speed shops wil have it.
JimS's Avatar
Originally Posted by trever1t
cmiller, Meth (methanol) is commonly called wood alcohol and is used to lower intake manifold temperature and increase octane. This allows the potentail for more timing without detonation (knock) in a forced induction aplication.
Correct me if i missed something.
Yep. What he said.
I'm happy with my Alky Control kit. I used their tank and mounted the pump to the radiator frame in front of the tank then ran the braided hose across the lower front cross member and into the Radix air intake tube about 4" in front of the throttle body and about 10 o'clock high as seen from the front of the truck.
Works great. Air temps stay below 150 even on 95 degree days at wot and the tank lets you know when you are low on washer fluid
Old Nov 1, 2006 | 07:32 PM
do u guys have the pump on the passenger side right behind the antifreez tank. and also are you guys using the windshield washerfluid tank or a different tank. if using the washerfluid tank will it harm any if i go that route with the pump on the passenger side in between the antifreeze tank and the firewall. i ordered the 2quarts tank but i think i would wanna use a i gallon to carry more.
Old Nov 1, 2006 | 07:53 PM
Last Call's Avatar
TOTM: January 2007
Both Trever1T and I use the factory washer tank for methanol as supplied by Alkycontrol. Both our pumps are mounted on the frame in front of the drivers front tire.
Old Nov 1, 2006 | 08:07 PM
Question
Where does the washer fluid tank mount at for the Alky kit??
Your not using the actual washer fluid tank that is mounted in the inner left front fender are you?
I'm confused abou this part..........
Jim
by doing that when turning the wheel it wont hit the pump or what i was thinking of doing that also
Old Nov 1, 2006 | 08:12 PM
trever1t's Avatar
Jim
New tank, same location, yes. You get a smaller tank to use for the washer fluid that mounts back under the hood support area.
Old Nov 1, 2006 | 08:15 PM
on the inline checkvalve do the arrows face towards the intake or pump
