Max boost
Old Feb 14, 2020 | 08:02 AM
dantheman1540's Avatar
Good tune and good gas for sure. My old 4.8 with TVS1900 ran 16psi all the time and with a new belt and cold air it would hit 18-19. Ran it 2 years and 25k miles like that pulled it for a bigger motor. Pump 93 and an Atomic tune plus it was a 2005 so gen 4 rods.
Old Feb 14, 2020 | 08:43 AM
smokinlmm's Avatar
The few times I've heard detonation was with sketchy fuel, I try to always fill up at a local station that sells a ton of 93 and has good quality fuel backed by a name brand. I personally use BP 93 with great results, occasionally I have to fill up else where so I add a little bottle of insurance to the tank. I sure doesn't hurt to be safe. Lol...
Old Feb 14, 2020 | 09:30 AM
MikeGyver's Avatar
He's going to run E85. You two guys are in a gasoline mind set.
Old Feb 14, 2020 | 09:44 AM
Yukon_inferno's Avatar
I use BP in my vehicles in general. I seem to have pretty good luck with them, but being that they don’t carry E85 (around me anyway), my options are a little more limited. Though I’ll definitely use tier 1. Lol
Old Feb 14, 2020 | 09:50 AM
arthursc2's Avatar
Fuel aside you still have a max torque limit your rods can hold
and cast pistons can't take the same abuse as forged
realistically you can run as much boost as you want. You just risk damage. E85 isn't always 85. I thinks it's E40-E90, so a flex fuel sensor is suggested
I'd stick around 12 and run extra timing. Better cooling, blower isn't being worked too hard, fueling is easy, Trans is probably ok and tires will last longer
Old Feb 18, 2020 | 10:43 AM
I agree on the E85 being not exactly consistent. I’ve also seen where it tends to have more frequent issues with water, whether it being related to the separation or maybe the fact that there aren’t as many purchasers so it sits longer.. idk.
And after doing some research and such I think 11-12 will be what I’m going to shoot for.. it should wake it up pretty well. I’m just waiting for the rest of the parts to arrive. Tick tock... !!
Old Feb 18, 2020 | 11:46 AM
Going from no boost to 12psi should make it feel like a raped ape. And then a week or so down the road it will feel slow and you will want 22psi lol
Old Feb 18, 2020 | 11:55 AM
😂😂😂 yeaaa, that tends to be like everything else I build... but I’m gonna keep that part a secret from my wife! 🤷🏻‍♂️
Old Feb 19, 2020 | 09:12 PM
Talstar's Avatar
I'm right there with you😂😂😂
chevrolade
Dec 29, 2008 10:27 AM
DOMLS2
Sep 17, 2008 02:39 PM
Mangled03gmc
May 29, 2008 10:05 AM
ogkevin13
Oct 28, 2005 10:27 AM
bigguy75inches
17
Sep 3, 2003 01:05 PM
