i want more boost!!!
Old Oct 27, 2005 | 12:38 AM
ogkevin13's Avatar
Banned
Default i want more boost!!!
can i run more boost with 40# delphi injectors and a fuel pump? and if yes how much more? its only a stock sts system at 5 pounds. and do i need to get n e thing else besides those 3 things (boost cont, pump,injectors) ?
Old Oct 27, 2005 | 12:44 AM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
im not familiar w/those injectors, if they fit trucks then i dont see why not, most go w/42s+ around here.. I imagine that the only other thing you would need woud be a tune.
Old Oct 28, 2005 | 08:38 AM
Mort's Avatar
Cool
I am currently running 10 psi with an in-line fuel pump, 44# injectors, boost control, and meth injection. I also have a boost guage, fuel pressure guage and logging software. I do not recommend going over 6 psi without them. My tune seems to be fine but I told him I expected to see over the rated 5 psi when I ordered the tune. I also run the low boost setting on the street for most of the time. The IATs will start to climb quite quickly when you raise the boost so keep an eye on them and your a/f ratio. You should monitor KR as well.
Have fun.
O ya and NGK TR6 plugs gapped at 0.035 if you do not already have them.
Old Oct 28, 2005 | 10:27 AM
F8L Z71's Avatar
Like Mort said,
Your problem wont be so much fuel delivery it will be moderating yoru IATs. After 5psi things get hot very quickly and the HP return/per lb of boost will degrade.
Look into an intercooler for best results then turn up the boost. Or go methanol injection. The Intercooler is my choice though.
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
