max boost for a 112hh
Old Sep 16, 2008 | 07:33 PM
DOMLS2's Avatar
Default max boost for a 112hh
what is the max boost for a 112hh,before you start to over spin it.
Old Sep 16, 2008 | 10:46 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Depends what engine it's on, mods, etc.
Old Sep 17, 2008 | 12:00 AM
Spoolin's Avatar
GFYS and STFU
555ci = 1 psi.
Old Sep 17, 2008 | 12:56 AM
ONLYA4.8L's Avatar
I would think bone stock bottom end with cam.. injectors and fuel pump
Old Sep 17, 2008 | 08:56 AM
leftcoast32's Avatar
FormerVendor
Dom - The 6 rib belt system is going to limit the Inlet Forward/Rear Drive 112HH to around 10-12 psi before slippage due to the belt stretching. I have not tried turning one up past 10 psi to see what else we could get out of it. I know of several with this design running 10 psi no problems on stock displacement and compression LS2's.
Old Sep 17, 2008 | 01:32 PM
T-CARDENAS's Avatar
leftcoast32: sorry to post thing that meybe dont belong to the thread, but what do you think a mp122 will do on a 6.0 engine, lets say it it bone stock
Old Sep 17, 2008 | 01:51 PM
FormerVendor
The biggest limiting factor will be the 6 rib pulley system above 10 psi on any of the systems. An 8 rib pulley system will bring that out because the belt will not stretch and slip as much.
The Truck Radix 122HH will do around 10 psi on a stock 6.0 with 6 rib pulley's.
The Inlet Forward 122HH will be good to higher boost levels because the rear drive can be underdriven, 1 to 1 or overdriven depending on application.
Old Sep 17, 2008 | 02:39 PM
zippy's Avatar
Efficiency wise I'd try to stay at 10psi and under. 10psi with 10:1 compression in your 6.0L and the right cam should get you the times you ran with the nitrous without having to use it as long as you can keep the blower cool enough. You can probably spin that fast enough to get 12-14psi out of it, but I'm not sure how much you'd gain at the track itself. It would dyno well, but probably run hot after the 1/8th mile.
GMCtrk
Jan 27, 2016 06:47 PM
gaps
Oct 15, 2015 02:53 PM
Justin87gn
Sep 10, 2015 12:06 PM
creekrat
Sep 10, 2015 12:59 AM
06murder
Sep 4, 2015 03:54 PM
