Magna Charger Vs Pro Charger
Old Apr 27, 2006 | 10:09 PM
BlownChevy's Avatar
blownerator
25 Year Member
Default Magna Charger Vs Pro Charger
Got some cool information today and I thought you guys would like to see it.
OK here is a test of the Magna Charger 112 VS Procharger D1 at 10 lbs boost on a stock 5.3 truck engine with a G2-3 Lingenfelter cam , timming was locked at 26 degrees and VP 103 was used, This test was done just a few weeks ago. As you can see the HP is the same at the same 10 lbs of boost.
Old Apr 27, 2006 | 10:26 PM
quicksilverado's Avatar
Big difference in the tq curve.
Old Apr 27, 2006 | 10:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
yep, right where you drive "under the curve"
Old Apr 27, 2006 | 10:39 PM
Richard@WCCH's Avatar
FormerVendor
Very impressive Magnusson torque curve Brian. Big torque bubble in the all important low and mid range rpms. Thank you for posting this info.
Richard
Old Apr 27, 2006 | 10:40 PM
BlownChevy's Avatar
blownerator
25 Year Member
Richard
wait until its tested with some WCCH "special" heads
Old Apr 27, 2006 | 10:48 PM
Bill Reid's Avatar
Heh... guess I'm glad I bought a Maggie today
Old Apr 27, 2006 | 10:49 PM
PappyDan's Avatar
Tribe Shaman
you probably wont have this info but I will ask any way.
at what rpm did the magna charger reach full boost of 10 psi?
at the rpm that the magna charger made full boost what was the boost from the procharger at the same rpm?
at what rpm did the procharger reach full boost of 10 psi?
at 5000 rpm's I see the magna charger is just past full torque.
at 5000 rpm's what was the psi of the procharger?
were both units intercooled ?
Old Apr 27, 2006 | 10:51 PM
BlownChevy's Avatar
blownerator
25 Year Member
both units where intercooled....the other info is on the charts.
Old Apr 27, 2006 | 11:07 PM
Low84's Avatar
You wouldn't happen to have any info on the Gen. 1 Classic-112 would you?
Old Apr 27, 2006 | 11:13 PM
TouchOfEvil04's Avatar
Wow,that magna destroyed it right out the box.
