maggie pulley
Old Jul 3, 2009 | 08:55 AM
lilmarv1117's Avatar
Default maggie pulley
OK, I am looking for some help with my s/c pulley.
I installed a new maggie 122 about 2 months ago and was getting belt squeel between 2k-3k rpm range, and I noticed that the s/c pulley sits back (towards the truck cab). I jut pulled the pulley off and tried to flip it to see if that would work, however, that made the misalignment even worse. So now I am thinking this s/c came with a spacer (it seems at least).
SO my question is: The s/c pulley is keyed and to put a washer behind the pulley would it be resting on the plate where the bolt goes it the s/c neck?? I am just afraid to tear the bolt, plate, pulley if I dont use the right part.
Thanks for help in advance..
Old Jul 3, 2009 | 09:29 AM
leftcoast32's Avatar
FormerVendor
You will need a spacer that only touches the inner race on the bearing and fits the shaft diameter. Alternator repair shops have spacers in different thicknesses that work real nice.
You will remove the retaining nut, pulley and then the key, put the spacer on. Then reassemble in reverse order.
Old Oct 14, 2009 | 09:23 AM
CashDudeHomie's Avatar
*revives dead thread*
How do I remove the key? Or do I cut a notch in the spacer? Also do I use locktite before tightening the nut to 45# or just dry?
Old Oct 14, 2009 | 12:04 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Small chisel and light taps with a hammer. It should come out pretty easy.
I used one drop of blue loctite on my pulley nut.
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
Justin87gn
Sep 10, 2015 12:06 PM
