LY6 boost limit ?
Old Oct 15, 2012 | 02:32 PM
sand man's Avatar
Default LY6 boost limit ?
will I sent Rick @ trick performance the cash to start building a turbo kit for a friend with a 2002 reg cb manual trans 1500 4x4 sierra
the truck has a stock 2008 LY6 with a 228R cam
we got the s480 turbo with a big custom FMIC
what is the LY6 boost limit , the stock CR is 9.7:1
stock piston ring gaps stock pistons stock heads
Old Oct 15, 2012 | 02:35 PM
nonnieselman's Avatar
Are you asking about the 2002 engine or the LY6?
You didnt mention which engine is the stock 2002
Old Oct 15, 2012 | 03:07 PM
sand man's Avatar
typo corrected
i ment a stock 2008 LY6
Old Oct 15, 2012 | 03:14 PM
Cool just checking...
with head studs and LS9 head gaskets, 20psi with a good fuel and a spot on tune should be quite fun.
but it all depends on fuel and tune at that point.
Old Oct 15, 2012 | 03:18 PM
sand man's Avatar
gas is 91 and if we can push 16psi on the stock rotating we would be happy
aiming for 600whp .. sounds resonable right?
Old Oct 15, 2012 | 03:19 PM
very easy.. i pushed mine to 15 psi this weekend and it was awesome.. (LQ4) but lean too by the end of the run
Old Oct 15, 2012 | 03:20 PM
Atomic's Avatar
I have a gauge for that
15-16psi would be as far as I would push it
Old Oct 15, 2012 | 03:22 PM
sand man's Avatar
lq4 has 9.4:1 and I suppose you run 93 gas
Old Oct 15, 2012 | 03:27 PM
oh just saw 91 octane..
might have to work the tune up slowly.. any plans for Methanol?
Old Oct 15, 2012 | 03:28 PM
Yep and Yep..
i just saw you said 91 oct.. might wanna start slowly at 10psi.
