LVTUNER TT 2012 GMC Single cab
Good to see Vegas is in the house. I have tuned 100's of cars & trucks Oakley but only tune the ones I build. Using NO ic BlackGMC will be easier to build, less expensive & will spool faster. A few reasons I do it this way. Fun to drive but not really a street race or drag truck set up. Too much heat at High boost but low boost no problem.
I like to street tune for a week and then see how she does on the dyno. I had good luck using Zippy's dyno in Las Vegas. Finishing the passenger side down pipe.
Been working on the oil feed and drain back lines. Drilled the oil pan and tapped into the oil cooler. Installed a lot of thermal material. Failed the MAF and started the engine today. Some exhaust work and ready for a drive. Still need to install the gates, so no WOT pulls yet.
DV2000NJ
May 8, 2017 10:54 PM
01SilveradoJakee
Mar 22, 2016 08:38 AM
tim wellington
Mar 1, 2016 10:11 PM
