LSA supercharger on a 2005 RST truck write-up
Old Mar 16, 2016 | 05:23 PM
  #71
shootermwc's Avatar
I wonder, if you had to bend down the steam pipe crossover with the adapters raising the blower, what would happen without the adapters in place.......?
Because I think I'm about to run into an issue haha
Old Mar 18, 2016 | 02:27 PM
  #72
myth's Avatar
On a nbs with out the adapters would the steam vent worse. Mine is a nnbs and the steam vent exits on the driver side. Not in the way at all.
Old Mar 19, 2016 | 09:04 PM
  #73
musclecity85's Avatar
i was wondering how are you guys swapping the stock upper pulley? every place ive taken it to cant do it cause they dont have the correct tool
Old Mar 20, 2016 | 09:57 AM
  #74
embs2001's Avatar
I think it can be done with a pulley puller and a press. Or even just a press. Remove your snout to use in the press.
Old Mar 21, 2016 | 10:03 AM
  #75
SUTTERERMAN85's Avatar
I work on helicopter gearboxes and have a press in my overhaul shop. Mine has been swapped out when I'm "working".
Old Mar 21, 2016 | 09:10 PM
  #76
Originally Posted by SUTTERERMAN85
I'm getting 13lbs on my 5.3l with a 2.5". Stock was 8.5lbs and 2.85" was close to 10lbs on a cool day. I only used the adapters off eBay and moved the alt and ps pump. Did mine in about 5 hours from start to finish.
Stock lsa map worked flawlessly. You need to find a different tuner. Only thing he need to do was change the map offsets. Very simple.
which belt did you use? i will basically be running the same setup with the 2.5 pulley. also do you have any pics of your belt routing?
Old Mar 22, 2016 | 08:49 AM
  #77
Your belt is going to be different based on where/how you move your alt and power steering pump to.
Old Mar 23, 2016 | 06:18 PM
  #78
also which plugs plugs are recommended with the lsa swap? im trying to gather my last few parts before i start my install
Old Apr 16, 2016 | 01:30 AM
  #79
FELONIOUS1's Avatar
I used a harmonic balancer puller and an 11mm socket, worked great!
Old Aug 31, 2016 | 03:55 PM
  #80
turboal1's Avatar
Default LSA install
well, has anybody else done this ?
I have been collecting parts to do this on my L9H 6.2 eng.
what probs have you encountered ? how did you fix them ?
