LSA supercharger on a 2005 RST truck write-up
Old Dec 19, 2015 | 10:02 PM
  #51
embs2001's Avatar
Originally Posted by Alco
do you guys use the stock truck crank pulley ? what kit do you buy to make it work it's not clear on the lssimple.com what I need to buy !??
Search eaby for Lsa truck 6 rib. His should pop up. Lucky for me he lives right down the road.
Old Dec 20, 2015 | 08:59 PM
  #52
Attached is the routing for the bypass valve.
Capping the lower port and running the upper port to vacuum is the proper way to plumb the bypass to allow it to still function properly. Just will not have the electronic solenoid that the LSA PCM's use for overboost, abuse, etc. protection.
Attached Thumbnails LSA supercharger on a 2005 RST truck write-up-lsa-bypass-solenoid.jpg
Old Dec 22, 2015 | 07:25 PM
  #53
embs2001's Avatar
Originally Posted by SUTTERERMAN85
8-9lbs is correct for a stock pulley. Yours is working correctly. I'm at about 10.5lbs with a 2.85. I was 8.5lbs on my 5.3l with a baby cam and all stock exhaust.
Do you guys have any problems with belt slip with the smaller pulleys? I am running the LSSimple 6 rib kit and wonder how small you can go before slip.
Where are you guys getting smaller 6 rib pulleys for the LSA blower?
Old Dec 22, 2015 | 07:48 PM
  #54
67goatman455's Avatar
Well I finally hit the dyno, the tune wasn't finished yet at this point obviously, it was actually running out of fuel pump. A quick fuel pump hot wire kit fixed it up though. I was hoping for 450 so I'm pretty happy!
Old Dec 22, 2015 | 09:21 PM
  #55
By the chart it looks like you need to adjust the fuel enrichment ramp in, takes an awfully long time to achieve the desired A/F ratio. Unless you are targetting +12 A/F ratio 4200 RPM and below
Old Dec 22, 2015 | 10:01 PM
  #56
Wolftrk99's Avatar
For not being conpletely tuned, cant argue at all....
Old Dec 23, 2015 | 08:02 PM
  #57
Argue with me, or OP? I know the OP said the tune wasn't finished but this setup is far off from its original life as N/A motor. Should do partial hits and begin to dial it in closer to your setpoints. Small steps
Old Dec 24, 2015 | 11:00 AM
  #58
Wolftrk99's Avatar
Not arguing with anyone, cant argue with results...
Old Dec 24, 2015 | 12:23 PM
  #59
Whoops, my fault. Definitely good power!
Old Dec 24, 2015 | 01:35 PM
  #60
blitzin247's Avatar
very nice. I am thinking about going this route as well.
