LSA supercharger on a 2005 RST truck write-up
Old Dec 12, 2017 | 04:25 PM
  #91
turboal1's Avatar
Default LSA Elbow
Capt-Kirk, this is what you need.
A 135* elbow will put the air tube/filter back
on the pass side
Attached Thumbnails LSA supercharger on a 2005 RST truck write-up-135-deg-silicone-hose.jpg   LSA supercharger on a 2005 RST truck write-up-135-deg-silicone-hose-2.jpg
Old Dec 12, 2017 | 04:38 PM
  #92
Vortec350ss's Avatar
you start pushing this thing to high horsepower and I promise you that creates a massive restriction pre blower.
Old Dec 12, 2017 | 07:15 PM
  #93
About20ninj45's Avatar
But it will help him get by until he relocates the battery and tube setup
Old Dec 13, 2017 | 02:33 AM
  #94
Capt-Kirk's Avatar
I ended up cutting my K&N CAI. I cut the 30 degree turn out, flipped it. and put in a 45 lines up great. I need to open some cold air slots and move the baffle to the driver side.
I drove the truck today less than 50% throttle to log data for Black bear.
Some thing about that little bit of boost makes the back of your ***** tingle.
Link to my photo album on this install.
https://photos.app.goo.gl/wUdbf6bijI7QLuJG2
Old Dec 13, 2017 | 04:42 PM
  #95
Ok. Dumb question. Is the injectors retainers required? The clips that hold the injectors to the rail
Old Dec 13, 2017 | 05:25 PM
  #96
turboal1's Avatar
Default Water fill
Is that your water fill for the
intercooler mounted up front
above the rad ? where did you get it from ?
I need one.
Old Dec 14, 2017 | 02:23 AM
  #97
Capt-Kirk's Avatar
Not a dumb question
My truck retainers were too big for the LSA rails
LSA retainers are $8 a pop
So i just installed the injectors and rails and they are held in place fine, next to no up and down play after installed.
I may buy some latter as i off road alot.
Old Dec 14, 2017 | 02:27 AM
  #98
Capt-Kirk's Avatar
The reservoir was an add on from Boost District contact Rosh
I placed it so the lower port would be higher than the top port on the LSA lid to aid in bleeding.
Bleeding was a bitch! I had to use a water hose under pressure with the pump on, even then the pump would out run the hose and run dry. I had to take the nozzel off the hose to push enough water through to get the air out.
Then I gravity bleed the water out and coolant in.
I need one.
Old Dec 28, 2017 | 03:39 AM
  #99
Capt-Kirk's Avatar
I have a vacuum leak and need help with EVAP and PCV.
How to route the Crank vents, catch can, and all with out inducing a leak?
Old Dec 31, 2017 | 10:51 PM
  #100
Capt-Kirk's Avatar
I got the LSA installed and Black Bear Performance is having trouble tuning it. They tell me i have a un mettered air leak just as boost is coming on. I cant find any leak, Others are saying the engine needs more fuel as the boost comes on.
Can you shed any light ?
https://forum.efilive.com/showthread...763#post242763
https://sites.google.com/view/lsa-silverado/home
Thanks
Chuck
