LSA supercharger on a 2005 RST truck write-up
Old Dec 31, 2017 | 11:14 PM
  #101
FFDP's Avatar
I'd look and offer advise but I have HP Tuners and not EFI Live.
So I can't see how they have the tune setup and how it runs.
Old Jan 1, 2018 | 09:55 AM
  #102
About20ninj45's Avatar
Question, eh hat fuel pump so you have?
Old Jan 1, 2018 | 10:50 AM
  #103
Atomic's Avatar
I have a gauge for that
If you still have the MAF your vented catch can is probably the issue. Either go SD only, or use a non-vented can, or a can with check valves.
Old Jan 2, 2018 | 09:49 PM
  #104
slimshaney's Avatar
Originally Posted by Capt-Kirk
I got the LSA installed and Black Bear Performance is having trouble tuning it. They tell me i have a un mettered air leak just as boost is coming on. I cant find any leak, Others are saying the engine needs more fuel as the boost comes on.
Can you shed any light ?
https://photos.app.goo.gl/wUdbf6bijI7QLuJG2
https://forum.efilive.com/showthread...763#post242763
https://sites.google.com/view/lsa-silverado/home
Thanks
Chuck
Did you get the leak solved? I can't help solve it, but am curious what you found. How's the tuning coming along?
Old Jan 8, 2018 | 04:14 AM
  #105
crutt's Avatar
I have a vacuum leak and need help with EVAP and PCV.
How to route the Crank vents, catch can, and all with out inducing a leak?
Intake->front passenger side valve cover-> rear driver cover vent-> catch can->blower vacuum.
Old Jan 10, 2018 | 08:25 PM
  #106
slimshaney's Avatar
The reservoir was an add on from Boost District contact Rosh
I placed it so the lower port would be higher than the top port on the LSA lid to aid in bleeding.
Bleeding was a bitch! I had to use a water hose under pressure with the pump on, even then the pump would out run the hose and run dry. I had to take the nozzel off the hose to push enough water through to get the air out.
Then I gravity bleed the water out and coolant in.
I wonder if flipping your pump upside down would help with bleeding. The coolant from the reservoir would then gravity feed directly into the pump.
Old Jan 18, 2018 | 08:31 PM
  #107
slimshaney's Avatar
Crutt......which alt/ps relocation bracket did you use on your conversion?
Thanks
Old Jan 18, 2018 | 09:00 PM
  #108
crutt's Avatar
Thanks
Olsen Kustom Works
Old May 3, 2018 | 04:17 AM
  #109
Capt-Kirk's Avatar
Old May 3, 2018 | 08:05 AM
  #110
Jonblarc7's Avatar
^^^^ that was a really good write up and very informative. I booked marked it.
Thanks
