Looking for missing power after 122HH upgrade...
Old Apr 28, 2009 | 07:14 PM
  #231
GoatChs's Avatar
Default Video...
Sorry it took me some time to get this up...none of the video sites will host the .MTS format of my HD camcorder! Had to buy $100 software to convert and upload to Youtube...
VIDEO
By the way, anyone know how to "embed" videos into the post?
Old Apr 28, 2009 | 07:38 PM
  #232
Last Call's Avatar
TOTM: January 2007
Originally Posted by supercharged tahoe ss
forged 6.0, 8.5 to 1 comp stock heads port and polished gt2-3 cam kenne bell 2.2 side mount with custom inercooler alky control e fans 160 stat 410 gears 4l80 swap vig3000 5 disk loc up dual 3 inch long tubes with high flow cats 100 shot 275/50 17 drag radials and 150 shot comming soon. i really love the kenne bell it make 10 pounds right out of the gate and stays there. wow i just noticed almost the same as you last call.
Awesome mod list man... Cool to see the Kenny Bell pulling nice numbers. Definately hauling ***.
Sorry for the high jack colby.
Old Apr 30, 2009 | 10:27 AM
  #233
NORCAL TBSS's Avatar
Restricted User
well went to the track yesterday 12.77@104.61 with a 1.72 60 foot time. the 275 40 17 work so good. im still on stock tune, and i still have torque managment in the trans. only mod was the yank 3600 from my 13.3 run and lost almost 6/10s and was like 20 mph head wind and das in the +1200 to +1500 range.
we will be doing a 75 shot next week on it should run high 11s.
Old Apr 30, 2009 | 04:10 PM
  #234
GoatChs's Avatar
No worries. We are all looking for the same thing here...good results!
Always windy out there...some times worse than other times. Over 1/2 sec improvement, you have to be pleased with that !
Old Apr 30, 2009 | 07:45 PM
  #235
supercharged tahoe ss's Avatar
colby that was a nice run I do 3 times that burn out and still cant hook like you your truck took off like a bullet I need to get some drag radials. i also like how your truck sits i still have the lowing keys in my garage i want to drop my front end down like yours.
Old May 2, 2009 | 07:38 PM
  #236
GoatChs's Avatar
colby that was a nice run I do 3 times that burn out and still cant hook like you your truck took off like a bullet I need to get some drag radials. i also like how your truck sits i still have the lowering keys in my garage i want to drop my front end down like yours.
That vid was my 2nd run, and I was still unsure of how much pedal I could give it...you can hear me pushing the pedal down harder a couple times as I was surprised that it was gripping. My first run I didn't burn them long enough and I was still spinning each time I stabbed it all the way out to maybe 300'?
As for the "rake", I currently have 2" drop Eibachs on the rear and cranked the torsion bars down in the front. I just bought a pair of 3" drop Eibachs & the GM lowering keys and will throw those in with a new set of torsion bars and upper control arms/ball joints soon...the front end is getting a bit soft AND loose.
Old Jul 11, 2009 | 11:09 AM
  #237
turboescalade's Avatar
any updates on that overdriven crank pulley, i'm wanting to do the same thing with mine
Old Jul 12, 2009 | 10:02 AM
  #238
GoatChs's Avatar
The truck is currently at Synergy having the ASP 8" 8-rib pulley conversion installed. The previous setup was the oem crank pulley with a 2.85" SC drive pulley...I'm going to use a 3.0" SC drive pulley with the 8-rib setup. Using this calculator, it should give a blower rotor increase of 1300 rpm @ 6000.
I should have waited to compare 'apples-to-apples' but I decided to have the blower cam installed at the same time...tired of the snail pace of getting things done and seeing the results. So, it won't really be able to tell which provided what percentage of the increase...the pulleys or the cam.
Old Jul 12, 2009 | 03:38 PM
  #239
old motorhead's Avatar
What blower cam did you decide to go with? Hope it exceeds your expectations!
Old Jul 12, 2009 | 08:24 PM
  #240
GoatChs's Avatar
I went with a Speed Inc SC-1 (222/228, .566/.571, 114). I don't know how much to hope to get, but I would like to see something more than a lope. Altho it should be pretty mild with the 383ci...the GT2-3 just doesn't scratch that itch.
The big concern now is the tranny...Rick was not thrilled with making more power on what he believes is likely a hurt transmission.
