Looking for missing power after 122HH upgrade...
Old Jul 22, 2009 | 12:54 AM
  #241
exodus's Avatar
so what are you doing with that old GT2-3 cam you have? lol I happen to be in the market for one.
Old Jul 22, 2009 | 08:54 PM
  #242
old motorhead's Avatar
Originally Posted by GoatChs
I went with a Speed Inc SC-1 (222/228, .566/.571, 114). I don't know how much to hope to get, but I would like to see something more than a lope. Altho it should be pretty mild with the 383ci...the GT2-3 just doesn't scratch that itch.
The big concern now is the tranny...Rick was not thrilled with making more power on what he believes is likely a hurt transmission.
Any news?
Old Jul 22, 2009 | 08:56 PM
  #243
GoatChs's Avatar
Depends on the results of the cam swap. If it make s more power and has decent driveability, I won't have a need for the GT2-3. But I won't let it go until I have some wheel time and track runs to ensure that I want to stay with the new cam.
Old Jul 25, 2009 | 06:14 PM
  #244
GoatChs's Avatar
Originally Posted by old motorhead
Any news?
Well, kinda...
Rick has reportedly contacted the "pulley supplier" on 5 separate occasions and has not received a positive response. The consensus is that we will put it together without the 8-rib SC pulley & idler, and will run a 6-rib belt until he can get this supplier to respond or find another source for the pulley/idler.
So, looks like I will run the new 8" crank pulley with a 2.85" SC pulley for now. Looking forward to seeing what that, combined with the new cam & Dynatech LTs does for it.
Btw, does anyone have a 3.0" 8-rib pulley for a front driven/rear inlet 122HH? lol
Old Sep 20, 2009 | 12:00 AM
  #245
GoatChs's Avatar
Default The Latest...
Picked up the Yukon from Rick this past week. Results of swapping the following:
1) JBA Ti-coated shorties with Magnaflow hi-flow catted y-pipe to Dynatech LTs & their hi-flow catted y-pipe,
2) LPE GT2-3 cam (207/220 573/581 118.5*) to Speed Inc. SC-1 cam (224/228 566/571 114*),
3) Oem crank pulley with 2.85 SC drive pulley to 8" crank pulley with 3.2 SC drive pulley
4) Magnason truck H/E to Magnuson CTS-V H/E.
Lost 7 rwhp, 6 rwtq, 2 lbs boost! But I did retain my 195* IATs at the end of a pull, so I didn't lose everything.
We had originally discussed and decided on a 3.0" SC drive pulley, but in the month plus it took to track down an 8-rib pulley for the 122, Rick forgot our discussion and order a 3.2". I think with the 3.0 it might have retained the boost and shown an overall improvement.
I will post the dyno & boost graphs when I get home. Transmission is still showing signs that it does not like the power/weight ratio! So, don't know if I will throw caution to the wind and hit the track until I have the cash saved up for a 4L80e.
Old Sep 20, 2009 | 01:16 AM
  #246
NORCAL TBSS's Avatar
Restricted User
i really dont get wtf is goin gon with your truck. its front driven correct??
there something going on and joe at left coast 32 has a cam specd out the lep sells get the guys 30 plus rwhp and didnt lose boost. I think cam swap gained a few gusy 25-35 at wheels but torque 40-50.
I wish you the best totally. At this point though i would do a 8 rib set up and run joes 2.7 race pulley boost prob 15 psi out of it and call it good.
Old Sep 20, 2009 | 12:57 PM
  #247
GoatChs's Avatar
Yup, front drive & I have just converted to an ASP 8-rib setup. It has been suggested that I mill the AFR 71cc heads down 64-65cc to reduce the combustion chamber size...thus allowing the 122hh to be more efficient at filling the cylinders. I will likely do this at some point.
Here's the graphs (old numbers are dashed lines), boost first:
Old Sep 20, 2009 | 01:05 PM
  #248
Restricted User
what heads are on there??? i would think the 118 would be better than 114 for blower app.
oh well hopefully see you at the track soon
Old Sep 20, 2009 | 01:12 PM
  #249
Restricted User
asp have bigger crank pulley?
Old Sep 20, 2009 | 03:49 PM
  #250
Last Call's Avatar
TOTM: January 2007
By the IAT's, it seems that the 122 is out of its efficiency range and blowing hot air. At that temperature, you are probably only getting 12-13 degrees of timing.
The engine has became more efficient if you are running 2 less pounds of boost and making similar power. Are you running meth? How is your vacuum at idle with that cam? Are you running a 90mm TB? DRx harness?
Stick with it man and you will figure it out.
