Looking for missing power after 122HH upgrade...
Old Sep 13, 2008 | 12:29 PM
  #131
DrX's Avatar
DrX
Originally Posted by zippy
Here's an example of a truck with the diff in discussion. It has the 9.5" 14 bolt SF with 4.10 gear and Gov-Lock.
Yeah, looks like the available ratios changed along with the introduction of the 6 speed.
2009 ordering info now shows only 2 available axle ratios 3.08(standard) and 3.42 which is either available or standard on L76 models dependent on whether the truck is 2WD or 4WD.
Old Sep 13, 2008 | 12:40 PM
  #132
leftcoast32's Avatar
FormerVendor
Make sure you dont get an SSR or TBSS 14 bolt because the wheel pattern is different from the rest of the trucks.
Old Sep 13, 2008 | 03:45 PM
  #133
Mr. Sandog's Avatar
Along with the track.
Old Sep 13, 2008 | 06:30 PM
  #134
GoatChs's Avatar
I'm going to get a 9.5" 14-bolt from a 2008 Escalade ESV. Want a GT5 rear but they are hard to find...the GU6 rears are much more prolific and affordable.
Old Sep 13, 2008 | 06:58 PM
  #135
supersub's Avatar
Did you call on the one i told you about?? it had the gt5 option listed.
Ray
Old Sep 13, 2008 | 10:06 PM
  #136
GoatChs's Avatar
Originally Posted by supersub
Did you call on the one i told you about?? it had the gt5 option listed. Ray
Sure did, and received the VIN. Checked the VIN with the dealer...was informed that it was from a 5.3L Suburban and not a 9.5" 14-bolt rear. So I did a search for GU6 3.42 and found I could get one from a Cad Escalade ESV with only 20 miles on it for $1325 delivered to my door--that is a brand new rear. I'm continuing to look for a GT5 until I confirm with this salvage if that includes brakes/lines, panhard, etc.
ANYONE CONFIRMED IF THE PANHARD ROD IS A DIFFERENT SHAPE TO FIT AROUND THE DIFF COVER?
Old Sep 15, 2008 | 08:47 AM
  #137
zippy's Avatar
I just got some pictures. They are on my cell phone so I'll have to wait to get home to post them. The panhard bar is the same part number as the normal one's and it clears the diff just fine. At least 1/4" to 3/8" of clearance in there. LOL. The picture should show that.
Old Sep 15, 2008 | 10:22 AM
  #138
Hawk179's Avatar
Not sure what you broke back there, but why dont you save time and cost and put a good posi unit back there. Do a standard eaton with a 800lb kit in it. You will never break that. Its stronger than the true trak.
R
Old Sep 15, 2008 | 07:16 PM
  #139
GoatChs's Avatar
I've started another thread to chronicle my 9.5" 14-bolt rearend swap HERE.
I'll continue to post here with the 383/122HH upgrade stuff (pulley, cam, tuning, etc).
Old Sep 15, 2008 | 07:45 PM
  #140
Last Call's Avatar
TOTM: January 2007
R
I can almost guarentee you that he will break the 10 bolt. I went through 2 Eatons and a Yukon Posi before I upgraded to the 14 bolt. I cracked the case on the Eaton. That was with a girdle as well. There is just too much flex in the housing. It is kind of like a 4l60/65/70e. In heavy applications with over 500rwhp, they are time bombs.
