Looking for missing power after 122HH upgrade...
Old Apr 20, 2009 | 04:23 PM
  #221
GoatChs's Avatar
Originally Posted by SincalT/A
What's up Colby.
I firmly believe in your setup.That big ol monster can suck all kinds of air but its got no where to put it.That exhaust you run leaves a lot on the table.When I heard you get on it you could hear the restriction.I got a nice 4" inlet outlet magnaflow with your name on it if you want it.
Hey Duane! I'm working to solve the issues one at a time...swapping out the JBAs to Dynatech LTs this week, and will probably have to do a custom catback, eventually.
Looks like I may be doing the 4L80 swap sooner than I had hoped.
Originally Posted by NORCAL TBSS
2-3 is a issue on the 4l70e on the supercharged and nitroused trailblazer ss also. youw ill have to adjust the rpm down from 2-3 to see if that helps if it still hits the limtier then set 2-3 shift 3 mph down and try it out.
Its not bumping the limiter since I have it shifting at 5800 and the rev limiter is at 6500. The engine will rev fine but there is no power being made there at this time so why go there, right? It just revs a little higher during the 2-3 gear shift.
It did not do this with the old tune, and since Rick (Synergy) started fresh with a "stock" rather than trying to figure out everything that the last tuner changed, I'm hoping that the "shift delay" can be tuned out.
Rick just moved his shop, and soon as he can accommodate, I will get it to him to check.
Old Apr 24, 2009 | 10:56 PM
  #222
supercharged tahoe ss's Avatar
I think you should hit 110mph if you hook I hit 109 and ran 12.4, I am going to the track in the morning with my new mods 4l80 ,inercooler ,410 gears ,and a 100 shot but i will run it straight motor 1st run and see what happens but i took some timming out for the nos, if you do put an 80 your truck colby make sure you put in a lock up switch it will help your mph. good luck.
Old Apr 24, 2009 | 11:02 PM
  #223
GoatChs's Avatar
Geez, your bus should really rip now! Be sure to report back on the new results...I'm eager to hear how she does!
I imagine that I will end up with a 4L80 sooner or later...and I will be sure to have a lock up converter when I do.
Old Apr 25, 2009 | 12:29 AM
  #224
NORCAL TBSS's Avatar
Restricted User
you going ot the track next week. I got hte yank 3600 in my wifes and this aint no joke!!!
Old Apr 25, 2009 | 09:45 AM
  #225
GoatChs's Avatar
Don't know yet. I have no reason to hit the track again...have not made any changes worth testing, and still have not made it to Fremont to have Rick check the trans.
Old Apr 25, 2009 | 11:03 AM
  #226
Restricted User
Oh ok tell me when you go again id like to run you on motor then on a 100 shot
Old Apr 26, 2009 | 04:38 PM
  #227
well the results are in i broke the tranfercase right off the line 1st run second run i ran in 2wd all motor and hit a 12.2 3rd run 12.1 at 115mph with the nos in 3rd bad start. i want to hit the nos right from the gate but no traction with my 275/55r20 street tires still waiting for my drag radials then i will for sure be in the 11,s and i also weighed my truck she is 6010lbs with me in it here is a video
Old Apr 27, 2009 | 01:33 PM
  #228
GoatChs's Avatar
Sorry to hear about the T-case BUT great runs!!! I'm amazed that you are that close to the 11s. The way mine is running I don't see me getting there without nitrous.
Old Apr 27, 2009 | 04:45 PM
  #229
Last Call's Avatar
TOTM: January 2007
Wow!! Impressive!!!!
What are your mods?
Old Apr 27, 2009 | 09:51 PM
  #230
forged 6.0, 8.5 to 1 comp stock heads port and polished gt2-3 cam kenne bell 2.2 side mount with custom inercooler alky control e fans 160 stat 410 gears 4l80 swap vig3000 5 disk loc up dual 3 inch long tubes with high flow cats 100 shot 275/50 17 drag radials and 150 shot comming soon. i really love the kenne bell it make 10 pounds right out of the gate and stays there. wow i just noticed almost the same as you last call.
