Looking for missing power after 122HH upgrade...
Old Sep 11, 2008 | 06:11 PM
  #121
supersub's Avatar
[QUOTE=GoatChs;3999025]As my wife does drive it on occasion, I don't want alot of odd noises and "pushing" that the Detroit would most likely give it...guess I'll aim for the TrueTrac then. I'll also do a quick search for the 14-bolt, but unfortunately I need to get the Yukon back up and running asap...have any specific thoughts on where to look (big salvage yards, etc.)?
Just checked car-part.com,select 07 escalade esv, rear axle,gt5 option,usa,one pops up in raito Ca...
Old Sep 11, 2008 | 07:20 PM
  #122
GoatChs's Avatar
Thank you very much...I had never seen car-part.com before.
And those have a "compatible" 5-link, coil spring suspension with 6x5.5 lug pattern? I wonder if it has any issues with the ABS...
Amazing...I will call them in the morning.
Old Sep 11, 2008 | 07:53 PM
  #123
supersub's Avatar
Should be a direct fit. I have been searching constantly for one closer.As far as the rear abs i was not planning to plug in the rear sensors.the ones listed locally for me have not been actual 14 bolt rears so confirm with pic's and vin break down...
Ray
Old Sep 11, 2008 | 10:15 PM
  #124
GoatChs's Avatar
Ray
Sounds like you have done your homework...do you know the year, vin/part number that ensures that you are getting the full floater and not semi-floater? I understand that the semi-floater has issues of its own?
Old Sep 11, 2008 | 10:24 PM
  #125
DrX's Avatar
DrX
My 14 bolt SF is finally done. The 5-Link bracketry was custom fabricated to match the factory AV setup.
Old Sep 12, 2008 | 06:44 AM
  #126
zippy's Avatar
The full floating 14 bolt is a 10.5" differential and only came in the 2500 series models. These had leaf springs. The 9.5" semi floaters rarely ever have any problems and are available from a 1500 series which had the factory 5 link system. The rpo you need is AXN.
Old Sep 12, 2008 | 11:41 AM
  #127
GoatChs's Avatar
Excellent work! But far from my abilities/resources...I'll definitely have to buy my way into a 14-bolt.
10-4...thank you.
Old Sep 12, 2008 | 12:11 PM
  #128
DrX's Avatar
DrX
10-4...thank you.
Actually, Bryan(axisT6) put this together for me along with the fab work by Mark of ceoffroad dot com Costwise it ends up pretty close doing it either way.
Still would like to see someone bolt-in a factory built 5-link 9 1/2" though. This should become easier to do as more used units become available over time.
Old Sep 12, 2008 | 12:27 PM
  #129
GoatChs's Avatar
PM SENT.
Old Sep 12, 2008 | 12:54 PM
  #130
zippy's Avatar
Here's an example of a truck with the diff in discussion. It has the 9.5" 14 bolt SF with 4.10 gear and Gov-Lock.
http://cgi.ebay.com/ebaymotors/Chevr...mZ150293786082
