Looking for intercooler options
Old Aug 25, 2009 | 09:48 PM
  #21
jetttstream's Avatar
Originally Posted by 95TwinTT
I’m sure you could find a place for the spray nozzle, downstream from the MAF.
I have been using Meth for three years now and no sign of problems with the IAT.
Just added alcohol to my Camaro this past year. It already had a liquid to air after cooler, but the alcohol allows me to get by with 92 octane instead of the race gas @ 15 psi boost.
My question is I read posts in which guys talk about IATs dropping when they spray the meth...well if it's post MAF, how am I measuring IATs to correctly adjust the tune, ya know?
IAT relocate post meth nozzle?
Old Aug 25, 2009 | 11:14 PM
  #22
95TwinTT's Avatar
Registered User
You also have a MAP sensor. That should compensate for density difference for the cooler air.
I don’t use a MAF sensor. To me the important battle is “pinging”. Pre ignition can do a lot of damage, not to mention sapping the power.
On my after cooler, I added a temp sensor for the coolant. The system is perfect for cruising and running on the strip, but for road racing, it gets “heat soaked” in a short time.
Old Aug 26, 2009 | 03:29 PM
  #23
I have a dashdaq(.com) account and aem (gauge, filter) account as well.
Long story short, I am testing those two devices and would also be testing an AEM coolant gauge (0-5v AND serial output---dashdaq does 0-5v input AND serial!) as well...so I would 100% for sure have a water temp sensor in the coolant (IC) circuit...especially for datalogging as well.
Interesting on the MAP, I will keep that in mind.
Now--slightly changing gears, can the Trick Flow A/C circuit be used on N/a intake models?
-Mike
$A_Money$81
Mar 27, 2023 10:25 AM
thompson
Dec 27, 2017 06:48 AM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
