KB Low-Mount Intercooler Pics?
Old Mar 21, 2012 | 09:47 PM
Ferocity02's Avatar
Default KB Low-Mount Intercooler Pics?
Anyone have pics of their low-mount between the frame rails intercooler kit that KB supplies? I'm curious how it mounts and what kind of airflow it can actually get. Thanks!
Old Mar 21, 2012 | 10:14 PM
black04silverado's Avatar
here is mine
Old Mar 21, 2012 | 10:47 PM
oakley6575's Avatar
Sorry for my ignorance, but why would you want to go low mount instead of behind the grille? Wouldn't you get a lot more airflow in front of the radiator?
Old Mar 22, 2012 | 12:04 AM
Ferocity02's Avatar
There isn't much room behind the grill on 99-02 trucks. It takes some serious modifications like cutting out the hood latch support and cutting the inside of the grill.
Old Mar 22, 2012 | 12:06 AM
oakley6575's Avatar
Oh so it's just a the year difference. Thanks for the answer.
Old Mar 22, 2012 | 12:17 AM
THE-HOE's Avatar
hope these help a little, i actually had to cut my bumper for mine to fit, but thats because i have a aftermarket one i believe.
Old Mar 22, 2012 | 09:32 AM
kbracing96's Avatar
It doesn't need a lot of air flow to work, it's a big heat sink. The air is only hot and needs cooling when your in boost, not all the time. The rest of the time it's in recovery with plenty of time to dissipate the little bit of heat it just absorbed for it's large size. Here is a pic of mine and I can show you 100's of IAT logs with very low IAT's at even 15 PSI of boost.
Old Mar 22, 2012 | 10:02 AM
Ferocity02's Avatar
Thanks for the pics. But the stock 99-02 Silverado lower valance doesn't have any holes in it for air to pass through, so it seems like whatever air it gets will have to be from what comes from underneath. Anyways, as long as you're not in boost a lot of the time it should have plenty of time to dissipate the heat regardless.
Old Mar 24, 2012 | 10:32 AM
kbracing96's Avatar
Most guys with those trucks just cut out the indentation parts to allow some air flow and they work great.
$A_Money$81
Mar 27, 2023 10:25 AM
SloSVO
Nov 22, 2020 07:34 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
GMCtrk
Oct 5, 2015 11:18 AM
