intake size on FI?
Old Mar 19, 2010 | 07:08 PM
scotthughes's Avatar
Banned Scammer
Default intake size on FI?
ive always been curious. when it comes to forced induction what is the ideal intake size. i know that normally the more air flow the better, obviously, but is there a such thing as to big? just thinking logicly i would guess that i would want to not go too big like a 102mm or anything because that would reduce pressure. these are just my guesses and have always wondered how that worked on forced induction. can someone please explain this to me?
Old Mar 19, 2010 | 07:55 PM
MikeGyver's Avatar
Originally Posted by scotthughes
... when it comes to forced induction what is the ideal intake size. ...
Bigger is closer to ideal, no matter what size you have.
... can someone please explain this to me? ...
Any restriction on the inlet on any type of forced induction is exactly that: a restriction. Any throttling of any kind will limit airflow. There is no ram air effect when it comes to forced induction. And on a turbo, there is no exhaust extraction effect past the turbo.
There would be no power benefit, ever, any time, of restricting the inlet side of a forced induction device.
Old Mar 19, 2010 | 08:08 PM
Banned Scammer
So basiclt its no different then normal? Even on forced induction?
Old Mar 19, 2010 | 08:29 PM
MikeGyver's Avatar
Uh... what?
Old Mar 19, 2010 | 11:08 PM
Banned Scammer
so basicly what your saying is FI or not, its the same principle as always. the more airflow the better. so if i was to go out and buy the 102mm from FAST and put use it with FI it would deffinatly be an improvement. Right or wrong? sorry im just trying to grasp this. forgive me for my ignorance on this
Old Mar 19, 2010 | 11:13 PM
SLO TRUCK's Avatar
Yup you got it.
Old Mar 19, 2010 | 11:19 PM
Banned Scammer
sweet. i was hoping that would be the answer. id like to get one.
Old Mar 19, 2010 | 11:23 PM
MikeGyver's Avatar
Install a vacuum gauge that you can read while you drive. Put the fitting at different places to check for restrictions: After the filter, after the MAF, and after the throttle. If either the MAF or filter cause a vacuum reading, then a bigger throttle probably wouldn't help until you changed the MAF or filter.
Stainless Works
13
Nov 5, 2015 03:31 PM
BlackGMC
Aug 17, 2015 07:07 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
