How far will 42#ers take me?
Old Oct 11, 2006 | 10:23 AM
  #61
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by TurboGibbs
Exactly, you are contradicting yourself by talking about trying to run 10's on a stock bottom end 6.0L in a 5600lb+ truck, running borderline small injectors, and running the maximum boost possible.
You run an engine on the ragged edge in a street vehicle and it will blow at sometime because there will be some point in time that that perfect situtuation you have it tuned for is going to go away without your control.
I'd suggest building it right the first time and keeping it conservative and you won't be breaking parts, that is no secret.
This is excellent advice. Over-built over-build over-build. Leave the ragged edge for full race vehicles.
Old Oct 11, 2006 | 10:28 AM
  #62
I AM A MOTHERF*CKER
Originally Posted by Blown06
What supporting equiptment is needed to run these 90+lb. injectors. Will the stock computer with Hptuners or efilive work?
Versafueler by acceleronics is the peak and hold driver I use. I believe Jim runs a flyback board on his megasquirt to drive 'em.
If you do a versafueler, you tune as per normal.
Old Oct 11, 2006 | 10:36 AM
  #63
Superado's Avatar
11 Second Truck Club
Details on 12v pumps available:
Features:
Self priming up to 8 vertical feet (2.4m)
Chemical resistant materials
Can run dry without damage
Built in check valve
Widely used in transmission and cooling system flush and fill, as well as filtration in aqueous parts washing equipment. The 8000 deliver high pressure, low current draw, and flows up to 1.8 GPM, (6.8 l/min). An extensive model range is available in DC or AC voltages, many chemical resistant materials, and with demand switch or internal bypass.
Model
Description
8000-443-236
Standard Demand Pump
1.8 GPM open flow, EPDM valves, Santoprene® diaphragm, 60 PSI Demand Switch, 3/8" NPT-Female ports, Poly Housing
8000-643-236
Transfer Pump
1.8 GPM open flow, Buna valves, Geolast® diaphragm, 60 PSI Demand Switch, 3/8" NPT-Female ports, Nylon Housing
8000-343-236
All Viton® Demand Pump
1.2 GPM open flow, Viton® valves, Viton® diaphragm, 60 PSI Demand Switch, 3/8" NPT-Female ports, Poly Housing
8000-543-238
High Pressure Demand Pump
1.8 GPM open flow, Viton® valves, Santoprene® diaphragm, 100 PSI Demand Switch, 3/8" NPT-Female ports, Poly Housing
8002-793-238
1.7 GPM open flow, EPDM valves, Santoprene® diaphragm, 100 PSI Demand Switch, 3/8" NPT-Female ports, Nylon Housing
8030-813-239
1.6 GPM open flow, Viton® valves, Santoprene® diaphragm, 150 PSI Demand Switch, 3/8" NPT-Female ports, Nylon Housing
8000-543-138
1.8 GPM open flow, Viton® valves, Santoprene® diaphragm, 100 PSI Demand Switch, 1/2" MPT-Male ports, Poly Housing
Old Oct 11, 2006 | 10:49 AM
  #64
parish8's Avatar
single digit dreamer
i dont think it will hurt the pumps to overdrive them just when under boost. the boostapump has a hobbs switch on it so it only ups the voltage when above 3psi.
Old Oct 11, 2006 | 10:51 AM
  #65
moregrip's Avatar
what a rush!
Originally Posted by dewmanshu
This is all very intersting to me. I always answer these fueling questions with the driveability and reliability in mind. Minus the top 10 fastest trucks here, cranking up the FP to 85psi to get 43lb'ers to make 617hp (as per the KB attachment) just isn't in the best interest of anybody. Nor will it be enough to feed Cody's desire to go 10 seconds in a 6L. What is the stats on how long these pumps are gonna last with that kind of voltage? Erik what is the IDC on 43's at 85psi? That's without meth. Cody I stick to my original post, 500 to 550. Why bother with something that is fuzzy or has a grey area unless you are okay with a short ending? KB says "...adequate for 560rwhp WITH the boost a pump." In reality going after 10's, you are gonna need more than a boost a pump and inline, but for now...Screw the boost a pump, get larger injectors and tune for them. You have an inline right? You'll have them when you'll need them and while you are trying to bust 10's you'll have enough fuel because the injectors aren't freaking open 100% of the time. Just seems this whole discussion would be better if you asked, "I am getting 96lbers, but I only want to put 600 to 700HP to the ground for now, what fuel support measures should I use? Boost a pump? Inline? Dual intank? Combinatin or all?" That's my unedumucated take on it at least.
FWIW, a walbro intank fuel pump with a KB BAP has proven dead reliable for a bro of mine supporting 600rwhp-ish
stock LQ4, 60lb injectors, KB BAP, 10lbs of boost, 50shot of N2O
Old Oct 11, 2006 | 11:09 AM
  #66
Superado's Avatar
Also...ShurFlo's sales rep leaned me toward the models with Santoprene diaphragms for use with meth...
Old Oct 11, 2006 | 06:08 PM
  #67
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Running it on the jagged edge woudl be for that one time deal at the track otherwise it will be turned way down for reliability that is what I am saying. I dont plan to max the damn thing out with a 300 shot or whatever all the time. I just wanted to see if I could push it to a 10 in its current form. The whole point of the thread was that I dont have the money for the versafueler and 96s right now so I wanted to know about what Im looking at hp wise with the 42s. I could always run the nitrous jetting rich to add a little more fuel also...
Old Oct 11, 2006 | 08:56 PM
  #68
dewmanshu's Avatar
Moderately Differentiated
this is exactly my point, KB says 560 with just the boost a pump on 42's. Your bro has 60'ers, boost apump,and an in tank. Perfectly safe system for 600HP. return system?
parish i am only questioning the ridiculous stats of getting 85psi out of a fuel system via a boost a pump. I understand it more than likely won't fail due to over voltage, it's not constant, but a stock pump? why waste the space on paper to give such a stat. If somebody is getting 85psi out of a stock pump to feed 42's to get 620hp...trouble?
Old Oct 11, 2006 | 09:09 PM
  #69
TurboGibbs's Avatar
All I am saying is you don't have the money for tools to fix the 418, or to buy 96's and a versafueler but you do have the money to buy a good used 6.0 and a good used STS system. If you would stick to one common goal you would have already had something going....but then you wouldn't be able to bench race like you specialize in instead of actually racing something.
Old Oct 11, 2006 | 09:22 PM
  #70
moregrip's Avatar
what a rush!
return system?
yes
