How far will 42#ers take me?
Tin Foil Hat Wearin' Fool
I have the marine 8.1 right now with a inline fuel pump. Im wondering how far it will take me with an sts kit, FMIC, gt-67, 6L, 220/218 cam, and a vic jr intake. I dont really want to buy 60#ers since in a year I will need 96s or bigger. I have a walbro intank fuel pump that I can throw in too. I plan on throwing meth on it soon also which I figure will buy me a # or 2 more. What is the best price ayone has found 60#ers for and where. PM me if necessary.
I was thinking I would push it 12#s and turn it up to 14ish for the track maybe just depends on how Allen says it is working when he tunes it. Wilde Racing hit over 500rwhp with the 42#ers and 12psi. Ill have a cam and vic jr intake over him so I "should" be able to put down about 60ish more hp then him thats why Im wondering if Im going to max these out and how much further the meth will crutch me along. Changing out injectors is a PITA even though it easy, and I would rather throw on the right ones right now since I could get 200ish for my 42#ers and then throw another 200 with it for some 60#ers but if I can get away with the 42s then Ill do that. Make sense?
If I remember correctly Parrish said his injector duty cycle dropped by 25% or 30% with a $hit load of meth. I don't know if that is what you were asking and not even sure if those % are correct, but I think they are
Mark
Mark
Originally Posted by TurboBerserker
~550-580 flywheel hp. 10-12psi is all you want unless you're doing internals.
I got first dibs on your used 60's next year once you finally realize you are getting them. LOL
Adkoonerstrator
I don't know what sorta power I have but, mine are around 96%dc at 7.5psi on a headered 6.0L. 55-58lbs of air through the MAF. I know they have more in them because they flooded my engine out at a 10:1 AFR when I made a mistake on the tune.
Don't forget if you spin the engine up higher you'll need bigger injectors because they'll have less time to inject fuel.
Go with the bigger injectors now and get it over with.
42# injectors, inline pump, voltage booster on the inline.
450rwhp=80% IDC
I dont think youre gonna get too far on the 42's. I'd buy the 60's and be done (until the 96's are needed)
42# injectors on your setup is like a stock 60E, yea it will work.......until it doesn't.
450rwhp=80% IDC
More money
