Help with procharger setup
Old May 8, 2011 | 11:15 PM
goinfast's Avatar
Default Help with procharger setup
hey guys, need a little help with my setup. i bought this truck last year for dirt cheap and have been trying to sort out all of its issues. its an 02 silverado ECSB 2wd with a 5.3 and a procharger D1SC making 12psi. the motor has been rebuilt with stock crank and rods with ARP bolts and has a set of custom wiesco pistons that dropped compression down to 8.5:1.still has stock heads, cam,intake and throttle body. all this was done by previous owner. the truck made 365rwhp through LT and a horrible 2.25inch exhaust. since ive owned it i put in a racetronix fuel system and hotwire, 60lb injectors, FLT lvl7 4l65e, yank pt3200, alky control meth kit and 3inch true duals with magnaflow xpipe and mufflers. what do think ill see on the dyno since my changes my goal for this truck is to run mid 12s id like to see about 450rwhp. Is this achievable with my current setup if not what should I change. Thanks
Old May 9, 2011 | 12:26 AM
Blown06's Avatar
8 Second Truck Club
My guess is that it will make just a hair over 450.
Old May 9, 2011 | 08:19 AM
sureshot's Avatar
All of the mods you've done are definitely taking your truck in the right direction. I think your goals will definitely be obtainable. You may want to consider a cam swap as well.
Old May 9, 2011 | 02:10 PM
goinfast's Avatar
thanks for the input, i wish the compression wasnt dropped so low it is a dog off of boost. do you think a custom grind cam might help with that? im leaning towards doing a cam swap next or should i throw on a tbss intake and ls2 throttle body?
Old May 9, 2011 | 02:50 PM
pewterliftedz's Avatar
dam that poor 5.3 needs some more compression. maybe think about working the heads and milling em' down a bit. at least to help you out when your out of boost...
like stated above, a cutom ground cam could do wonders for your goals..
Old May 9, 2011 | 02:58 PM
Mangled03gmc's Avatar
Baltimore Whore
The 8.5 is def low compression for that small boost level.. I say boost it up to 15lbs.. 450 seems to be a good guess, I think it should do close to that number.. Maybe find a set of 243 heads, have them milled to get you back to around 9.5 or so compression...
Old May 9, 2011 | 04:16 PM
Bad_Apple's Avatar
I agree and throw a cam in it and that will make a huge gain in performance and bottom end.
Old May 10, 2011 | 04:15 AM
goinfast's Avatar
Thanks for the input guys. I think I'm gonna up the boost for now and start saving for some heads and a cam
Old May 11, 2011 | 09:21 PM
Rick_Vor's Avatar
If he is already running the stock 853's or 706's, he's already at 61.15cc. not a lot of room to mill and 243's are going to drop it even further.
With the right tune, you'll nail mid 12's @ 12lbs.
Time to turn it up. You've got plenty of injectors and pump. Maybe add a 2nd Alky nozzle and crank up it to 16-18 lbs. You've got a solid foundation (minus a good centri cam) so your biggest problem will probably be belt slip.
A nice set of small chamber AFR's or TF's and a good cam will do wonders for your top end and ET.
Rick
Old May 12, 2011 | 02:28 PM
goinfast's Avatar
Thanks the info on the heads I saw that the TF's had 58cc chambers which would help. I'm gonna do a leak down test this wknd. If it's good im gonna throw more boost at it and if not time to get a 6.0. Do you think I'll need a 2nd nozzle at 16lbs? I'm gonna pin the crank too who makes the best kit?
simman22
Jan 21, 2017 10:27 PM
MOBBN
Sep 22, 2015 08:07 PM
murderedSS
Sep 22, 2015 03:53 AM
00loudchevy
Sep 11, 2015 07:55 AM
Justin87gn
Sep 10, 2015 12:06 PM
