Heat shielding
Old Jun 20, 2012 | 11:36 AM
scooter k's Avatar
Default Heat shielding
Just wondering how much of the wires and stuff are you turbo guys covering?
I find myself wanting to cover everything that is close and wanting a guess of how many inches away can stuff be and not be covered?
Old Jun 20, 2012 | 12:01 PM
Ferocity02's Avatar
Good info, I would also like to know what needs to be protected. I'm assuming the passenger side plug wires and the heater hoses, but other than that I can't think of what else needs to be covered. I haven't put the kit in yet, just hypothesizing right now.
Old Jun 20, 2012 | 12:11 PM
nonnieselman's Avatar
Im in the process of wrapping all the hotside. and doulbe wrapping the log manifold to hopefully keep the heat off the plug wires.
Guess we will see.
Old Jun 20, 2012 | 12:14 PM
TrickTurbo's Avatar
Truck Sponsor
Turbo blanket
wrap down pipe
hear sleeve a/c low side suction line.
Those are pretty standard.
Wrapping the manifold help hold heat but also the wrap gets you closer to the wires.
Heater hoses should be anywere close to the hot stuff.
We have covered the oil feed line.
If your turbo is to close water tank you might need to cover tank.
But the blanket should solve most if not all heat issues.
Old Jun 20, 2012 | 12:15 PM
Originally Posted by TrickPerformanceProducts
Turbo blanket
wrap down pipe
Heater hoses shouldnt be anywere close to the hot stuff.
there ya go.
Old Jun 20, 2012 | 12:17 PM
TrickTurbo's Avatar
Truck Sponsor
Thanks.
Old Jun 20, 2012 | 12:23 PM
Ferocity02's Avatar
there ya go.
What's wrong with superheating the coolant into the heater core, might be nice on cold mornings
Old Jun 20, 2012 | 12:31 PM
Oh it would work awesome.. right before all the coolant wanted to leave the hose in a hurry by the new found daylight.
Old Jun 20, 2012 | 12:32 PM
Thanks.
just wanted to make sure nobody got the wrong idea.
Old Jun 20, 2012 | 12:54 PM
Atomic's Avatar
I have a gauge for that
I covered everything remotely close...
And my turbo blanket itself still gets over 200 degrees
