Found a problem with drain oil to the valve cover.
Old Nov 14, 2005 | 10:28 AM
NXRICKY's Avatar
Former Vendor
Default Found a problem with drain oil to the valve cover.
Ok this weekend I found that draining the oil to the valve cover might not be the best idea.. On a steep decline, the truck likes to smoke. A bunch. Guess I will be moving it some as I can get to it.
Ricky
Old Nov 14, 2005 | 10:49 AM
TG02Z71's Avatar
Ricky
So that's your return line plumbed into the top of the valve cover?
Maybe it will work in another location on the cover, the STS system dumps it back into the cap, I know you probably don't want to do that but maybe its where it dumping it, not the fact that its dumping it onder the valve cover?
Do you know exactly what is under that peticular spot on the cover?
Old Nov 14, 2005 | 11:45 AM
kbracing96's Avatar
He is using gravity to dump the oil back there, where the STS is using a pump. It's hard to get oil to run up hill
Old Nov 14, 2005 | 11:51 AM
TG02Z71's Avatar
So gravity VS pumping why would it be smoking?
Running into the top of a leaky valve seal?
Old Nov 14, 2005 | 02:32 PM
kbracing96's Avatar
When he goes down a long hill, the tube that the turbo is draining though, is then running up hill to the valve cover and oil is backing up into the turbo causing it to smoke. I think that's what he is talking about.
Old Nov 14, 2005 | 02:48 PM
TG02Z71's Avatar
"I see" said young Grasshopper, "now it makes sense".
Thanks for the clarification.
Old Nov 14, 2005 | 03:37 PM
NXRICKY's Avatar
Former Vendor
yeppers thats what I am talking about, again only on a steep downhill... But the new turbo will be setting higher, and I will go ahead and go back to the pan... Damm just did not want to pull the pan... I hate getting dirty. lol
Ricky
Old Nov 15, 2005 | 09:41 AM
Lord Aries's Avatar
I am going to move my Oil return to my pan from the VC when i feel like giving myself a headache for a weekend project... LoL 8-)
The_W
Oct 28, 2015 09:00 PM
Noah Burns
Sep 7, 2015 05:50 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
hartinclay
Aug 3, 2015 07:03 PM
Mzay
Jul 6, 2015 11:03 PM
