Found the oil burning culprit finally :)
Old Jul 29, 2008 | 06:32 PM
  #41
CHEVRACER83's Avatar
Originally Posted by thunder550
Shannon, I'm glad it didn't let go. I sent pics to my buddy who works for Honeywell Turbo and he said that is definitely debris damage, not heat damage. It could have been a lot worse!
YOUR REAL LUCKY THEN AGAIN THATS THE EXHAUST TURBINE... MINE WAS THE COMPRESSOR WHEEL.... AND IT TOO SOME HARD PARTS WITH IT....
TAHT WAS AN EXPENSIVE LESSON IN HOW FRAGILE ENGINES ARE
Old Jul 29, 2008 | 11:30 PM
  #42
vanillagorilla's Avatar
Why didn't you just go with an S series AirWerks unit?
Old Jul 29, 2008 | 11:37 PM
  #43
thunder550's Avatar
High on diesel fumes
The deal I got on the Garrett turbo was too good to pass up.
Old Jul 29, 2008 | 11:50 PM
  #44
stock48's Avatar
9 Second Truck Club
No excuses for December!!
Devan, I think I remember my log file saying that we were doing 120+...definitely moving out. I can't even imagine the RPM that turbo was spinning, pushing 15psi into a 408ci engine turning 5700 RPM....
Here is the one I roasted on my Dmax from high egt's. Looks similar to yours.
Old Jul 30, 2008 | 12:18 PM
  #45
kbracing96's Avatar
I would have to say it was from excessive EGT's too, look at the way the gouged fins are folded back with the direction of rotation, like they got hot and started melting and just started coming off and folding back. The turbo that came with my STS kit had a turbine wheel that looked just like that when I bought it. I found a guy that had a new wheel and shaft and I just installed it, and it was still going strong last I heard. If it was from debris, the chunks of wheel would be folded forward from the contact with the debris hitting them as it "push" though the turbine. That's my thought on it any way Glad you got a new one on the way though
Old Jul 31, 2008 | 04:09 PM
  #46
s/c'd cav's Avatar
i agree with heat , if it was debris , it would have a couple fins folded over , then damaged , then a few good 1's , unless the piece has been embedded into the case
i would think having to make the 90 outta the head , 60 or so sweeper into the down tube , 90 to the pass side and 90 back up into the log , the 45 or so into the straight section of the log and then 90 up into the turbo woulda been enough to slow any chunks down
plus the fact the piston was still intact , as was the head , only real damage was the scoring from the piston and cylinder trying to weld themselves together , which goes with high egt's
but then what do i know , my twin t's are a table right now , lmao
Corvette454l88
Sep 1, 2016 01:24 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
08DenaliT
Jul 8, 2015 09:13 PM
