FI Technical Discussuion to End All! 2nd try :)
#101
Originally Posted by vanillagorilla
I think what he's saying is that it'll climb steadily through its rated or intended rpm range.
Any hard data on this grippy?
Now with that said, is it possible for VE to increase and/or maintain a high percentage when spun past 14,000rpm? Reread the statement above, there's an important component to a draw through system, "a big gulp of fresh air"
#102
Originally Posted by whitt1
OK,so where do I find a 2.5" pulley?I bet a Radix will really scream at 20,000 rpm.This might be the ultimate Radix durability test.
ATI will make you one if you send in your stock piece.
#103
So,how long will a Radix last spinning 20,000 rpm?Will it make any more boost at 20,000RPM?How high will the IAT's go?How much would a 100hp shot of nitrous boost power?And when the Radix comes apart how much damage will it do?
#104
Originally Posted by moregrip
I'm just trying to spurn thought without giving up all the answers; look at a 4th gen chart, you can prove the above statement, as you stated.
Now with that said, is it possible for VE to increase and/or maintain a high percentage when spun past 14,000rpm? Reread the statement above, there's an important component to a draw through system, hint: 7eleven invented it
, based on the ve chart i am prety sure the ve will fall off above 14,000rpm. any compresor is going to have a sweet spot and it looks like 14,000rpm is the sweet spot. above this point you will start to see diminishing returns. that isn't saying it wont make more power as you spin it past 14,000rpm but the gains per rpm increase will be less and less as the rpms go up.
#105
too hard, don't know, next question
besides, you wouldn't believe me if I told you.
#106
If you know for a fact that the supercharger will live at 20,000rpm a larger crank pulley can be built by ASP,L-eater has one on his intercooled Whipple setup.I just don't know if the result from investing $300 on a crank pulley would payoff in increased performance.
#107
this thread is here to discuss facts absolutely, but we will also allow some discussion on what may or may not work for a specific type of FI, what you've heard or learned or just some idea you've had that makes sense to you that you want to bounce off someone.
let me post the Premise again:
Premise:
Lets talk about the pros and cons of each FI power adder. Let's see facts and forward thinking, This is not meant to be a bash on ANY power adder...any direct hits at ANY manufacture that do not have facts to back them up will be deleted. Have at it folks.....lets see the knowledge, lets talk about what might and might not work, tell us what you know, share your experiences, and lets keep this one respectful and proper when discussing our different views
lets allow everyone the oppurtunity to express themselves however they wish as long as they are not disrespecting anyone or attacking a manufacturer and it's on topic.
Premise:
#108
(Cleaned up my mess.
Sorry for being such a pig.
) One question which has been asked is what are the upper speed limits of a blower? Well, besides mechanical strength, I believe (recalling the graphs from memory) that airflow increases linearly with speed, but the required power to spin the unit increases at some rate faster than linear. Therefore, a point will be reached where any additional power gained by increasing rpm's will be offset by a greater increase in power draw, and net power will decrease. Also, as Brian Z pointed out elsewhere, at high speeds the blower becomes very sensitive to inlet flow restrictions. This makes sense, for on the output a restriction can be overcome with increased pressure, but on the intake, one is limited to a maximum of 14.7 psia pressure. Thus the larger aftermarket intake netted about 15-20 hp in his test. I suspect this is also why he is going with a dual blower system on his truck. By having two intakes, he can effectively double the amount of incoming air, something that would be very difficult to do with a single intake system.
#109
Attention: I am pruning this thread of any off topic posts/posts that do not directly contribute to the thread topic, thanks
No data or "on topic" discussion is being affected.
Premise:
Enjoy!
Premise:
Enjoy!
#110
Originally Posted by DrX
Let's continue on with the heat issue. As you mentioned there are several sources of heat including compression(and where it takes place), friction. recycling(roots), heat soak, etc.
We can discuss the compression end of it more but after doing some logging today I was reminded that my IATs would go up around 10*C during a short WOT run but they would increase 10-20* more while shutdown or idling. So unless you keep moving, you are starting out in the hole for the next run. Are some FI systems more affected by heat soak than others? What can we do to mitigate this factor?
