Excessive turbo smoke!!! Need help please
Brand new 7875 VS Racing
I have an .030" oil restrictor at the turbo, and a .060" on the motor oil feed line(-4)
PLEASE HELP! I'm lost
This is the 2nd new turbo on the truck, the first was a 72mm ball bearing CXRacing( I'm really sure, that's what the tag decoded to) that turbo also smoked. But no where nearly as bad as this one
FWIW my truck makes about 60-65lbs of oil pressure when hot and about 85-90lbs at WOT hot. I also run Mobil 1 5/30
The oil feed/drain kit from Trick Perf. With the kit
Gammey4: the oil drain is just about middle of the oil pan
