E85 question
Old Dec 11, 2007 | 06:11 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by kbracing96
Mileage doesnt get cut in half, there is 30% less energy content in a gal of E85, but the real works reports are about a 10-12% drop in mileage, but about a 5% increase in power on NA setups when tuned for it because of the 105 octane rating. I have researched this a lot and really want to do it, but I never live any where where I have access to it on a regular bases. You can run it with only change 1 table in the tune, but to maximize it you should do some tweaking to others. The fuel systems in these truck are capable of handling it.
It is harder to start in cold weather, but some tuning tweeks can help that.
Do you really think GM would use parts that fail with 85% ethanol when there going to build both systems and even the non-FF vehicles have to be able to run 10-15% ethanol? There are quite a few people that have done conversations with after market injector modifier boxes only and I haven't heard of any that have had fuel system component failure problems.
I really think there is some gains to be had especially being forced inducted with this fuel. This is something I REALLY want to do, just to do it!
I picked up 36HP, and 44LBS (flywheel) on a NA 650HP carburated BB chevy! At this altitude the 85 makes a big difference, and that is in cold weather. With FI, and a hot day the advantage of the E85 will be HUGE.
Old Dec 11, 2007 | 07:38 PM
kbracing96's Avatar
Originally Posted by stock48
Thanks. Will the E85 eat up the lines?
Your lines should be fine They don't put rubber lines on these things any more
Old Dec 15, 2007 | 01:08 PM
wtftalon's Avatar
e85 is a huge benifit if tuned right. i have a 92 eagle talon, upgraded turbo and other small stuff and with e85 your able to push more boost and throw more timing at it. also have an 01 seirra that will be turbo and e85 shortly. cold start is a problem below 30 degrees, just takes a little longer to start.
Old Dec 15, 2007 | 07:59 PM
stock48's Avatar
9 Second Truck Club
That is what Im thinking should handle 18-20LBS, with no KR and have a cooler IAT. Could be worth a almost a full second on a summer day, and not kill the engine.
Old Dec 15, 2007 | 08:05 PM
00Silv4.8's Avatar
...I would be If I could get it, but down where you are should be easy to come by...
you cant get E85 in AZ? um.. theres a guy with a 5.3 on a vortech that runs somethin like a 14 I think (dont quote me) and he runs all Ethanol.. so uh.. AZ gets it? where are u?
Old Dec 15, 2007 | 11:40 PM
mcconditioner's Avatar
Damn theres an e85 station 4 miles from my house, I could run a winter premium pcm and an e85 for the summer once I boost the denali. Would the e85 help significantly in a nitrous application or just better on forced induction applications due to the temp drop during atomization of the ethanol?
Old Dec 16, 2007 | 02:17 AM
stock48's Avatar
9 Second Truck Club
Should help with N20 also due to the higher octain. Just places more demand on the fuel system. Takes roughly 30% more Injector, fuel pump, and line size than gas. Might be the ticket with the Denali high CR.
blownss27
Aug 14, 2020 08:27 AM
Justin87gn
Sep 10, 2015 12:06 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
