Done deal.. Maxed out 4.8L/76mm Magnum. Next?
Old Oct 13, 2012 | 10:00 AM
  #191
LS1FREEK's Avatar
13 Second Truck Club
This is the same timing table I'm using on my 89 and on my brothers 4.8 (Jake99) mabe we could use more yet? We're both running on straight E85
The boost timing is the one I was using on my 89 at the track running 50/50 91/E85
Old Oct 13, 2012 | 10:03 AM
  #192
LS1FREEK's Avatar
Originally Posted by sprayedenali
I forgot I don't have Internet at home so this is the best I can do...
Damn dude, .64/.68 is usually WOT on NA, isn't that a lot of timing 45*@2400???
Old Oct 13, 2012 | 10:13 AM
  #193
Atomic's Avatar
I have a gauge for that
WOT is usually around .84
Old Oct 13, 2012 | 01:31 PM
  #194
sprayedenali's Avatar
It's a calculated number that will be different for every combo...
But hey, you gota do something to make a 5000lb ext cab with a stock motor go fast!
Old Oct 13, 2012 | 04:46 PM
  #195
foose04's Avatar
Thanks for posting up guys. I'll be getting home tomorrow. You all got me excited about tossing some timing in this girl down low. I also want to try one more thing to see if I can get more flow with the 40mm wastegate. One is clean up the flanges to make sure i'm getting a full 40mm, and also cut a coil on the spring and test it with compressed air. If the valve move further back, it should flow more.
That doesn't work I got a hit on a local with a brand new JGS 60mm gate for 425. I'll likely pick that up. That almost a 2.5" valve, so damn, thats venting the whole left bank, should get the job done.
Old Oct 13, 2012 | 04:57 PM
  #196
foose04's Avatar
Originally Posted by xx_ED_xx
Hey Foose, I am doing a similar build to what your truck started out as. 4.8 ls6 cam 5 speed single 76mm. It is for the ol lady to drive thinking 15 psi inter cooler. Make a custom pass manifold turbo mount. What size injectors you recommend? Any other recommendations?
If your going with pump 93, I would give yourself some room and go with some 60's and call it a day. E85, go with 80s. Next, honestly if it's for you old lady, a 76mm@10psi & a stick wiil make well over 500 wheel and be hand full for her. My 70mm made 523/523 at 10psi and 17 degree's timing. You would also likely be fine with 15-17 timing on 93 and 10psi with a good intercooler.
Once 10psi starts feeling slow, or she's feeling froggy, then turn it up.
Old Oct 13, 2012 | 05:39 PM
  #197
lglowe's Avatar
If you end up having to get a bigger gate I might buy your other one to run duals. I'm pretty sure im not gonna be able to go low boost with the new Borg I got coming
Old Oct 15, 2012 | 06:12 PM
  #198
foose04's Avatar
Little update, got the 5" intake in and turbine blanket. Hope to have 60mm JGS installed tomorrow, then maybe track Wednesday for some testing if I get a tune on her in time.
Old Oct 15, 2012 | 06:28 PM
  #199
Atomic's Avatar
'bout time for a custom coolant res, wouldnt you say?
Old Oct 15, 2012 | 06:34 PM
  #200
ak2007r6's Avatar
That intake elbow coming off that turbo looks like a elephant trunk LOL
