D1-SC with 255 Walbro
Old Nov 24, 2007 | 08:40 PM
bpope's Avatar
Default D1-SC with 255 Walbro
Hi Guys,
Just wanted to make sure I was going to be covered with my setup. I have a 5.3l and am getting ready to install my ProCharger D1-SC. I am going to be running 60 lb. injectors with a 255 lph Walbro in-tank pump. I am just wondering if the pump will be enough for my setup. The truck is an '04 model and I am completely stock right now except for a Hooker muffler.
I figured the 255 would be enough, but I have a friend with a Supercharged Vette who said when he was at 425 hp N/A he was seeing a drop in pressure and then it would get steady. I am wondering if I need a BAP or if you guys are doing OK with just the 255 in the tank. I will be running 9-10 psi and I think will be close to 400 whp.
Thanks for the help.
Old Nov 24, 2007 | 09:18 PM
Casey2323's Avatar
Yes u should be Fine... @ worst case later on you install a Hotwire kit The bigger injectors will help because the IDC will stay pretty low and help the pump keep up with the Load
Old Nov 24, 2007 | 09:56 PM
bpope's Avatar
Thanks for the reply...what exactly is a HotWire kit? Sorry, I just haven't ever heard of that.
Old Nov 24, 2007 | 10:16 PM
Regency04's Avatar
Default Superchager
Hey Whats up, what all have you done to the motor to handle the supercharger?
Old Nov 24, 2007 | 10:21 PM
bpope's Avatar
The motor is bone stock... with the exception of TR6 plugs. I have a lot of faith in my tuner so I am not worried about the engine with 60 lbers and a fairly conservative tune. The tranny on the other hand....
Old Nov 24, 2007 | 10:59 PM
Blown06's Avatar
8 Second Truck Club
Good luck only making 9-10 psi. I had basically your exact set up and saw 12 psi on the dyno and 14psi on the street during the 1-2 shift. What I'm trying to say is that a D1 with the supplied 4" pulley on a stock 5.3 will make more boost than you want.
I also had a broke piston in 2 days. Be careful, make sure your tune is perfect, or you'll be in the same boat I was in.
You can search for some of my older posts and read up on it.
Old Nov 25, 2007 | 08:28 AM
bpope's Avatar
Blown06--Thanks again for the suggestions. Were you tuned on 93 when you smoked the piston and also what was the timing set at if you remember?
Old Nov 25, 2007 | 02:45 PM
Blown06's Avatar
8 Second Truck Club
Yea, I was running 93 gas. Don't remember what the timing was set at. I would suggest you don't go over 18 to 20 degrees. Maybe others have better input on that.
Old Dec 1, 2007 | 02:05 AM
Regency04's Avatar
on my 4.8 i only had 42lb injectors and the stock fuel pump with 12 psi. when i did mine i had to change out the rod cap bolts and if i could of done it over again i would of upgrade my oil pump and i had 480rwhp
Chavette
Oct 28, 2015 07:33 PM
Vortec350ss
Oct 10, 2015 09:11 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
slocaddy
Sep 25, 2015 12:42 PM
Justin87gn
Sep 10, 2015 12:06 PM
