cam, stall for procharger
Old Jul 13, 2010 | 08:37 PM
jg53's Avatar
Default cam, stall for procharger
I recently bought a procharger.
As of now I have a cam, specs 214/220 .600/.523 115 LSA
As well as the Circle D 3200 278mm stall.
My question
will these two work with the procharger. the high lift on the intake side concerns me on the cam, and im not to sure about the stall should i go with something smaller?
im also plannning on buying the DOD delete kit and a P&P shaner TB
Truck is a CCSB details in the sig.
Old Jul 13, 2010 | 08:51 PM
smokeshow's Avatar
Mod with training wheels
Stall might be a bit too high for you. I have a 2800 stall and it's a little high for my taste. Granted I do have a blower that puts out boost a little sooner than the centrifugal, but you might still have some wasted powerband with the procharger.
Old Jul 13, 2010 | 09:01 PM
jg53's Avatar
could i save some money and buy me a tbss stock stall?
Old Jul 13, 2010 | 09:06 PM
smokeshow's Avatar
Saving your money is entirely up to you lol. I believe the TBSS stalls are around 1900, which is actually a bit low. I plan to restall eventually, most likely the 2400 range.
Old Jul 13, 2010 | 09:07 PM
swift700's Avatar
I don't think the high lift would be any problem with that cam... quite the opposite. It has a fairly short duration and a good LSA for FI. The high lift will let in more charge during the allocated duration without excessive overlap allowing it to blow out the exhaust valve. Also, it should be pretty good on fuel for normal driving. Sounds like a decent cam IMO.
Old Jul 13, 2010 | 09:31 PM
jg53's Avatar
well going FI isnt cheap, so I dont want to cut any corners if i am doing this. I think i might shoot for something a little smaller in stall then. probably something like yours sounds about right.
Old Jul 13, 2010 | 09:32 PM
jg53's Avatar
Thanks for the info.
Yes I want to keep this thing a close to street friendly as possible since it will be my DD, but still have some go when I want to have fun
Old Jul 13, 2010 | 09:42 PM
phasemaster1's Avatar
will work fine Id save a few bucks not getting the TB.
Old Jul 13, 2010 | 09:44 PM
jg53's Avatar
So I Just did some quick searching, I might shoot for something like this
http://www.circledspecialties.com/p-...converter.aspx
Old Jul 13, 2010 | 09:46 PM
swift700's Avatar
I forget to mention, that cam should make good torque, which is always good in a heavy truck. That being said, I wouldn't go too high on the TC stall. Normally, a high stall works better on a cam with lots of duration and low LSA. Those cams make power in the higher RPM range. With your cam and a blower, you don't want to bypass all that low end torque. I tend to think that a 2400-2600 stall would be just right.
