Cam for LS2 with maggie?
Old Jan 28, 2007 | 05:10 PM
NORCAL TBSS's Avatar
Restricted User
Default Cam for LS2 with maggie?
ok stock heads, maggie has 2.9 and 2.8 pulley, long tube headers and true 3 inch duals on my tbss. Now i forgot the exact name but would the l2-gt3 or something like that cam be my best bet? and im not changing the heads
Old Jan 28, 2007 | 05:31 PM
Stoichiometric's Avatar
The GT2-3 (207/220 571/.578 118.5) is the most popular cam around here for the maggie. I went with a GT-7 ( 208/230 .554/.546 121) and 1.8 rockers to get my valve lift up to ~.600". I still need to install it, so I have no performance reports yet. If you are using stock rockers, I would pick the GT2-3.
Old Jan 28, 2007 | 05:34 PM
Restricted User
how about gt2-5??
Old Jan 28, 2007 | 05:40 PM
Restricted User
someone was saying the gt2-3 was for stock exhuast or something like that. I have long tubes and true duals.
The 112 lobe separation will increase the overlap and bleed boost and lessen dynamic compression. If you are having detonation problems that might be an interesting choice. The 118.5 lsa on the GT2-3 will keep the dynamic compression higher. What is the ls2 compression ratio?
Old Jan 28, 2007 | 05:42 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The gt2-3 has proven itself with the radix, but cant think of a LS2 running one. Both you guys are going to show up next month, right?
Old Jan 28, 2007 | 05:43 PM
Restricted User
10.9 is the compression of a LS2
they also have a GT7 and a gt2-5
Old Jan 28, 2007 | 05:44 PM
trever1t's Avatar
I have shorty headers but from there back is pretty much free flowing. I am very happy where the LPEGT2-3 makes its power in my 5.3L.
Old Jan 28, 2007 | 05:47 PM
Restricted User
heres the specs for the GT7
208/230 .554/.546 121CL
And this is what they say
Suggested for supercharged or turbo charged applications. LPE has developed several new camshaft profiles for the LS1& LS6 engine to improve horsepower and torque without sacrificing the LS1’s driveability.
then the gt2-5 specs
222/222 .566/.566 w 1.7 rocker 112 CL
Now what rockers do the ls2s have stock?? and also for a blower wouldnt a higher lobe separation be better??
Old Jan 28, 2007 | 05:48 PM
Restricted User
trevor what size pipes are you running?
im running 1 3/4 long tube with 3 inch true duals all the way to the tip. Muffler is 3 inch dual in/out with internal x pipe.
