Cam for LS2 with maggie?
Old Jan 28, 2007 | 06:44 PM
  #21
NORCAL TBSS's Avatar
Restricted User
yah i have 1 3/4 and im sure that will do its job. with stock heads dont know how much the 1 7/8 would help. the gt7 has less lift and i dont want to spend another $$$$ to bring it up but if i had 1.8 rockers i would do that.
Seems to me the gt2-3 is the way to go.
Some member on the other site used the gt2-3 on his stock trailblazer ss and this is what he dynoed. no other mods than electric fan swap. this was thru stock exhaust and stock manifolds
you can see the red is the stock set up which turns off at 130 mph. he just took off the limiter to get past that 130 on the new setup
Old Jan 28, 2007 | 06:57 PM
  #22
Restricted User
one more thing the gt7 has less lift but a higher lobe separation. What would that do for me? would a higher lobe sep be better to go with if you lose some lift?
Old Jan 28, 2007 | 07:25 PM
  #23
Stoichiometric's Avatar
No. I would stick with the GT2-3.
Old Jan 28, 2007 | 08:25 PM
  #24
Restricted User
ok ill talk to brian tomm see exactly what he says.
Old Jan 28, 2007 | 08:27 PM
  #25
moregrip's Avatar
what a rush!
what does magnuson say about the gt2-3 in your high compression application? Might want to give John a buzz over there
Old Jan 29, 2007 | 03:17 PM
  #26
Restricted User
Well talked to kevin at ligenfelter and he said they never used them in the LS2 before and for a fact they know it helps in the truck applications but for a LS2 its a little bump up but not really as much as if i was using the truck 6.0L. Ill wait off on this until i see some results with a LS2 and a cam with a maggie.
Thanks for all your guys help.
Old Feb 1, 2007 | 09:22 AM
  #27
black2003ss's Avatar
Does that chart show a 70hp and about 70tq gain from the GT2-3 cam and tuning? Wow...
greedygenius
Sep 3, 2015 06:51 AM
Denali08
Aug 9, 2015 04:34 PM
Ammadien
Jul 22, 2015 08:50 PM
jmarkway
Jul 18, 2015 09:23 PM
caviness
Jul 5, 2015 10:49 PM
