brace for procharger
Old Feb 21, 2015 | 06:52 PM
  #21
George C....'s Avatar
Formerly ScreamingL
Originally Posted by 02_Orange_D1SC
well this up coming spring i should have a mid 10sec truck i plan on beating the
10.46 @ 126 you did a few years ago
and a still think the procharger bracket is junk
he went 10.4? thought he was 10.7 or so?
Old Feb 21, 2015 | 08:02 PM
  #22
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
yes blown06 went 10.46 @ 126 few years back with the mainly stock procharger kit
Old Feb 25, 2015 | 09:49 PM
  #23
http://vid187.photobucket.com/albums...psc3flqom7.mp4
i know the video sucks but if you look at the drain line from the head unit and the bolt with the wires you can see the bracket moving
the motor moves around also from the rubber mounts so it makes it kinds hard to see
Old Feb 25, 2015 | 11:40 PM
  #24
Blown06's Avatar
8 Second Truck Club
The majority of that looks like the motor moving. Whats going on there?
Old Feb 25, 2015 | 11:52 PM
  #25
Vortec350ss's Avatar
I've watched him do that first hand and I know the bracket has flex. You can see the bracket move in comparison to the silver area behind it with the ground on it. It seems that it could be a bit of an optical illusion where the bracket is so much closer to the camera, and maybe it is a little bit. But not really. With the trans bolted in place there is no way the whole motor would rotate in the engine bay that much. I can see rocking side to side or even lifting, but not much front to back or rotating on a flat plane the way he is putting pressure on it.
I guess the next best thing to do would be to take the same video with the bracket in place to show how it improves.
Old Feb 26, 2015 | 08:05 PM
  #26
I'm pretty sure my truck needs motor mounts they are 14 years old
Old Feb 26, 2015 | 10:11 PM
  #27
Formerly ScreamingL
your using the trucks oil system to supply oil to the procharger like a turbo does?
my unit is self contained
that motor is moving a good bit but hows it moving when under load? do a go pro video to see for sure
Old Feb 27, 2015 | 03:43 PM
  #28
my is self contained also my drain line is extended so its long enough to go underneath the truck
my truck isn't running as of now I'm doing a fuel cell but i plan on welding up my stock motor mounts
Old Mar 2, 2015 | 10:22 AM
  #29
ProChargerTECH's Avatar
FormerVendor
The stock ProCharger bracket kit was designed for mainly stock trucks, with mild combos.
Since that is 99% of the supercharger systems we sell for trucks.
(unlike mustangs and camaros)
Another ProCharger dealer offered a "Direct Drive" system for a while for higher HP trucks.
So we didn't have a real rush to make a "DD" system, since that smaller "niche" was being filled.
Old Apr 8, 2015 | 03:13 PM
  #30
marlboroman71818's Avatar
coming from a procharger owner that i paid dearly for, this is probably the worst comment Ive heard a company give. I mean I like my procharger, but this makes me reconsider all the procharger sales pitches i believed and that i should just swap to a turbo setup so I dont have any procharger parts that are simply not strong enough to hold up.
