bov ?
Old Sep 3, 2006 | 08:35 PM
silver-bullet's Avatar
Default bov ?
well i am putting a intercooler on my whipple s/c and have been looking at piping kits. alot of the kits have bov's that come with them. i was just curiouse if i would be able to use it or if i should ditch it. i am going to block off the bypass on the whipple so i was just curiouse if this would work. THNX!
Old Sep 3, 2006 | 08:38 PM
nightrunner's Avatar
Mr. Obvious
idk ive only heard of bovs on turbos...
Old Sep 3, 2006 | 08:46 PM
that is what i was curiouse about. i would think that it would work but i don't know if anyone has thought of trying it before. being that they both produce boost i would think the bov would work the same for a s/c as it does for a turbo.
Old Sep 3, 2006 | 11:03 PM
03sierraslt's Avatar
The boost is not produced the same way though, with a blower when you let off the gas your blower immediately decreases speed with rpm. With a turbo it takes a second or so. Also if you are looking at the ebay piping kits you will most likely find that the couplers and clamps are crap. Just some FYI.
Old Sep 3, 2006 | 11:04 PM
Also on your whipple your bypass valve opens as soon as you let off which also bleeds off the boost.
Old Sep 4, 2006 | 02:13 AM
Stoichiometric's Avatar
Does your whipple push or pull through the throttle? Usually the BOV lets out extra pressure that is created when you shut the throttle and the turbo is still making boost. If you are "pulling" through the throttle I don't think you would need a BOV.
Old Sep 4, 2006 | 08:00 AM
Mr. Obvious
he said in the first post that he was going to block of the bypass valve
i personally dont know how you would do that but...
Old Sep 4, 2006 | 09:14 AM
i found the bypass instructions under this thread.https://www.performancetrucks.net/fo...pple+piggyback
Old Sep 4, 2006 | 10:36 AM
You dont actually eliminate the by pass, you just eliminate whipples shitty electronic control that they use and use vaccum to control it. You have to have the by pass on there.....
JordanH
Feb 19, 2019 07:46 AM
03chevytruck
Nov 7, 2016 04:43 PM
Tuckin15s
Sep 23, 2015 09:35 PM
97_ek
Sep 23, 2015 09:16 PM
6.0l RST
Jul 7, 2015 02:22 PM
