on3 turbo kit issues
Old Jul 6, 2015 | 07:51 PM
6.0l RST's Avatar
Default on3 turbo kit issues
in the middle of doing my kit trying to tune it, have bov ran to intake plenum and when i start the truck it opens and stays open at idle. any thoughts? too soft spring? junk bov?
Old Jul 6, 2015 | 08:09 PM
GMCtrk's Avatar
Stiffer spring
Old Jul 6, 2015 | 08:11 PM
6.0l RST's Avatar
is on3 bov a copy of tials how do i order a stiffer spring because on3 suuuuuuuuuuuucks to deal with
Old Jul 6, 2015 | 09:03 PM
ezdaar's Avatar
Nm, i derped, had waste gate in head.
Old Jul 6, 2015 | 09:05 PM
George C....'s Avatar
Formerly ScreamingL
with a SD setup the BOV can be open at idle if you choose it to be, however it needs to close fast once pedal is pushed so you can build boost better
having it open at idle will only make air noise when a SD tune, when a maf tune it needs to be closed
Old Jul 6, 2015 | 09:15 PM
6.0l RST's Avatar
its going sd but were supposed to plumb the bov into the tube the bov is into? thats confusing?
Old Jul 7, 2015 | 12:44 AM
08lambochevy's Avatar
I have the kit on mine with a SD tune, my bov stays open at idle and as soon as there is any throttle it seals shut, its perfectly fine
Old Jul 7, 2015 | 06:36 AM
6.0l RST's Avatar
Where's it plumbed too
Old Jul 7, 2015 | 06:52 AM
Formerly ScreamingL
Bov are vented to atmosphere
Recirculating valves dump back into pipe ahead of turbo or blower
Old Jul 7, 2015 | 07:01 AM
6.0l RST's Avatar
So having the top vacuum line into the plenum is a no?
