Blower air temps?
Old Jan 16, 2020 | 09:20 PM
TrickTurbo's Avatar
Truck Sponsor
Default Blower air temps?
So for the blower cars & trucks.
Magnuson/Whipple/LSA etc. how are your air temps? How hard are you pushing the blower psi and your air temps?
Last edited by 03sierraslt; Jan 17, 2020 at 04:04 AM. Reason: Air turbos ??? Fixed
Old Jan 16, 2020 | 11:36 PM
arthursc2's Avatar
Procharger P1 thru an air to water, 12lbs. 77 ambient, 92 IAT at end of pull. Pretty much stagnated there. We did 4-5 more pills and never saw 100
Old Jan 17, 2020 | 04:53 AM
smokinlmm's Avatar
At 14 pounds I'm making some heat, I'm at 125 to 130 at the end of the 1/4 but I drive it an hour to the track so it's throughly heat soaked.
Old Jan 17, 2020 | 06:40 AM
dantheman1540's Avatar
At 16psi on my TVS1900 I would see anywhere from 120s to peaking into the 140s during Florida summers. Average driving is 15-20* above ambient.
Old Jan 17, 2020 | 06:53 AM
zz454Chevelle67's Avatar
My Magnuson Radix MP112 is at 7 psi and runs 40 above ambient all the time just normal driving. Its coming off soon, going turbo.
Old Jan 17, 2020 | 07:31 AM
smokinlmm's Avatar
Same here, typically only 15 over ambient and it will go down to 8 above during most normal driving conditions.
Old Jan 17, 2020 | 09:20 AM
Last Call's Avatar
TOTM: January 2007
My Whipple runs 15-20 over ambient, and typically climbs about 20-30 degrees on a pull. One of the biggest issues is the heat soak when turning the engine off and then restarting it before it cools down. I can see 140-150 degrees on start up depending on ambient temp. I now I have a switch to run the fans and intercooler pump with the engine off to help with that.
Are you thinking of something for us blower guys?
Old Jan 17, 2020 | 09:25 AM
I also see terrible heat soak up to 150s if I shut it off say at the gas pump for 5 or 10 minutes.
Old Jan 17, 2020 | 11:09 AM
03sierraslt's Avatar
I bet he is, it’s called a Turbo.
sorry, had too.
Old Jan 17, 2020 | 11:27 AM
terravast4's Avatar
maybe a big *** heat exchanger
